Infamous SignalMinder RM3?
indybobm:
Could be something very simple. Take off the right side cover. Find the wire harness that goes to the rear lights. They should be in a opaque cover. The Lt. Blue connection to the right rear light might have become disconnected. The SM3 usually connects to the wiring using Scotch connectors which are notorious for cutting through wire strands. It could also be a bad connection at the top of the rear wheel where the rear light assemble connects to the bike. I fought mine for years, always chasing down connection problems. The last straw was when the element in front turn signal bulb broke and shorted out . This caused a massive problem in the SM3. finally took it out and went back to the stock turn signal relay. IMO, not worth the hassle.
Navigation
[0] Message Index
[*] Previous page
