Different Style Valk Adjustable Brake and Clutch Levers
mello dude:
Looking closer at the YmotoX levers, the clutch doesn't look right.
Doesn't have the open space to slide the OEM bushing on.
Photo shows under side of clutch lever and OEM brake lever.
Probably best to research what common master cylinders are on other Honda bikes that are same as the Valk,.
-mike-:
You're right.
The clutch lever doesn't look exactly like the one I got.
I looked up the old invoice from 2021 where it said chrome adjustable brake and clutch lever for Honda CB 1300.
The original offer isn't online anymore.
So I did a search with these words where I bought it (on Ali) and came up with the product linked above.
Nevertheless there are fitting sets out there. Just be careful with descriptions or pictures! Lesson learned.
-mike-
-mike-:
I simply couldn't leave it like that, so I walked over to my garage and made pictures.
I even found the plastic bag the levers were shipped searching for the OEM handles...
The label says
CB 1300 98-08
These levers are a direct drop in indeed, even if they somewhat look a bit different on the mechanical end.
See mounted and on comparison to OEM.
Best of luck,
-mike-
TrapperAH1G:
Thanks for going the extra mile!
Navigation
[0] Message Index
[*] Previous page
