New member with a big leak.
<< < (3/5) > >>
Mooskee:
Quote from: KTRT on August 25, 2025, 05:32:36 AM
Found the leak.
The T shaped plastic piece on the left bank, between carb between carb 4 and 6 if I’m not mistaken
Yup, so it was definitely the o-rings. They were so dry they all snapped in two when I wanted to remove them.
Yep. Very common unfortunately.
KTRT:
Eh, I like wrenching, and I knew from the get go I’d have to clean the carbs anyway.
Besides, while I’m waiting for the kit, I was able to find some tubing to do some vacuum lines, those were horrible too, and I’ll replace the timing belts, just in case.
KTRT:
Okay, small dumb question as I’m busying myself with the hoses.
https://oem-bike-parts.com/en/parts/honda/1100cc/gl-1500-gold-wing/gl1500ctw-valkyrie-1998/e-20-1-carburetor-pipe
Number 14, what are those hoses linked to?
And while I’m at it, does anyone has a trick for hoses that are stuck to plastic parts? I was trying to remove the draining hoses without breaking the plastic piece in the middle, and kinda stop before breaking it.
Timbo1:
Quote from: KTRT on August 28, 2025, 04:37:30 AM
I may be wrong but I believe those are vent / overflow tubes that go into the rear stay.
This kinda shows where they go if I'm thinking of the right part. Youtube Link
On stuck hoses for me it's 50/50 on if I can get them off without causing more damage.  I take a small pick or screwdriver and try to get it between the hose and connector then rotate it.  Sometimes the rubber has deteriorated to much and cracks.
Mooskee:
Timbo is correct. The #14 hoses are vent tubes and remain open to atmosphere. When fuel enters the bowl, the air goes out those tubes. The are placed in the rear stay as Timbo stated.
Navigation
[0] Message Index
[#] Next page
[*] Previous page
