What oil are you using in your Valkyrie? ---- Survey only please
<< < (6/7) > >>
F6Dave:
Quote from: RonA on September 04, 2025, 02:25:42 PM
Pretty sure that T4 is conventional, T5 is a con. syn. blend, and T6 is a full syn.
It was. I looked it up and in 2021 Shell changed the formula and now it's a blend.
F6Dave:
As i mentioned earlier I recently switched from Mobil 1 15W-50 to Rotella T4 15W-40. I had the oil analyzed for both. Wear metals were the same, but they use different anti-wear packages. Mobil 1 has more moly and magnesium while Rotella has more boron and calcium. In my Valk it made no difference.
mello dude:
I hate going here.... but on T6 .... what is the change?
Per survey, it doesnt seem to concern many of us.
Joe333x:
Quote from: mello dude on September 06, 2025, 05:56:18 PM
Yeah idk, I've been using T6 in my motorcycles for over 20 years now and this is the only site I have seen someone say something about a change to it that effects motorcycles? The bottle has a picture of a motorcycle on it and it still says JASO on the back so unless I see some type of concrete evidence that I shouldn't use it, I'll keep using it. It's in both of my bikes right now.
98valk:
Quote from: Joe333x on September 07, 2025, 09:31:18 AM
T6 5w40 does not meet the Ford spec so shouldn't be used.
the T6 15w40 does meet the Ford spec and can be used.
https://www.shell.us/business/fuels-and-lubricants/lubricants-for-business/products/shell-rotella-heavy-duty-engine-oils-for-fleets/shell-rotella-t6-full-synthetic-heavy-duty-engine-oil.html
Navigation
[0] Message Index
[#] Next page
[*] Previous page
