July 31, 2010, 06:43:38 PM *
Ultimate Seats Link f6rider link
Valkyrie Bling and More
Author Topic: DESMOG FREEZE PLUG PROBLEM  (Read 1242 times)
rh_customs
« on: May 11, 2009, 11:25:09 AM »
  Has anyone had problems after a desmog with the freeze plugs on the top blowing out. I did a desmog a few months back and yesterday had the second plug blow out, first one happened the day of the desmog.
RH
SCain
Rio Rancho, NM
« Reply #1 on: May 11, 2009, 11:33:30 AM »
I put some permatex sealant on mine when I installed them two years ago, never had a problem. I remember using the NAPA plugs and they were rather tight getting in.
Steve
1999 Black Interstate
NM VRCC State Rep
DFragn
« Reply #2 on: May 11, 2009, 11:36:26 AM »
Originally I had left the tubes in place, but kept blowing the caps off. So I did a full desmog.
I knocked the plugs down tight, about a 1/2" then filled to the top with JB Weld then wetted my finger and finished the exposed surface off smooth. It looks good and have never had a problem blowing them out.
Kingbee
Northern Illinois
« Reply #3 on: May 11, 2009, 05:39:33 PM »
Specifically, what did you wet your finger with - some special solvent?   crazy2
99 Interstate
00 Interstate
04 Rune
08 Goldwing w/airbag (and I don't mean Queenbee)
DFragn
« Reply #4 on: May 11, 2009, 06:58:11 PM »
Ya know full well my special solvent is naturally 'sputum'. I mean spit.  crazy2
« Last Edit: May 11, 2009, 11:33:54 PM by DFragn » Logged
Hopkinsville, Kentucky
« Reply #5 on: May 11, 2009, 07:35:50 PM »
I desmogged 4 years ago. I put in 14mm freeze plugs without any sealer and left the tops of the plugs exposed ( no jb weld ect.) They haven't moved or deteriorated in any way.
Momz
Compost happens!
S.E. Michigan
« Reply #6 on: May 11, 2009, 08:29:09 PM »
I blew out 2 freeze plugs in one week. My permanent solution was to remove the other two, use 5/16th button head screws, they will just thread in the smaller of the bores, then fill the rest of the area above the button head with JB Weld.
Always...QUESTION AUTORITY!
The price of Freedom is Ever Vigilance.
It's only sick and perverted the first time.
rh_customs
« Reply #7 on: May 12, 2009, 01:07:48 AM »
   Thanks to all for the reply's, picked up some new plugs today may try with some JB Weld, not to much though, out here in California you never know what new laws they'll pass, may need to put all the smog junk back on one day to go through smog inspection?
Thanks again
RH
Madmike
Peace River , Alberta
« Reply #8 on: May 12, 2009, 03:03:03 PM »
seems to be lots of this going around lately...... are you fellows using the "cup style plugs" or the "convex ones"Huh?Huh?Huh?Huh?
Tropic traveler
Livin' the Valk life in Central Florida.
Ocala, Florida
« Reply #9 on: May 12, 2009, 03:54:13 PM »
Use the cup style plugs, drive them all the way down until they bottom out. Make sure you drive them in absolutely straight & you should have no problems. Did my '97 that way 30,000 miles ago, still good to go.
If you use no sealant & don't epoxy over the top it should be a fairly simple job to extract them at a later date if you have to. cooldude
'97 Valkyrie Tourer for me.
'98 Valkyrie Tourer for Kim.
'05 Shadow Spirit 750 for her too.
'99 Valkyrie Standard FOR SALE!!!
'05 Triumph Rocket 3, gone but not forgotten.
Eddie
« Reply #10 on: May 12, 2009, 04:34:23 PM »
"Cup" style for me also.
Madmike
« Reply #11 on: May 13, 2009, 08:00:23 AM »
Is the fact that the plugs are being blown out an indication of another problem??
Tropic traveler
Ocala, Florida
« Reply #12 on: May 13, 2009, 08:32:32 AM »
No, not really a problem. The holes that we plug off for a de-smog are connected to the exhaust port with constant exhaust pulses trying to push out the hole. If whatever is used to plug the hole off isn't seated or sealed real good, exhaust will come out!
Eddie
Hogdaddy
« Reply #13 on: March 15, 2010, 07:11:47 PM »
Where you guys getting the freeze plugs? Called most of the autoparts stores and none around Lake Charles La. area. Thanks
« Last Edit: March 15, 2010, 07:19:47 PM by Hogdaddy » Logged
Madmike
« Reply #14 on: March 15, 2010, 07:23:39 PM »
9/16 or 14mm as I recall, should be no problem at any good autoparts or industrial supply - ask for a cupplug or expansion plug....
cupplugs
mirion
1997 Std - 2000 IS
Frankenmuth, Michigan
« Reply #15 on: March 15, 2010, 07:46:44 PM »
I used the 9/16 cup type plug which is actually .010 tighter than 14mm. I used a little LocTite on them and then went one step further after reading about someones who blew out. After pressing them in a little past flush I usd a prick punch and put a punch every 90 degrees around the plug hole to peen the aluminum over the plug. Maybe overkill and maybe not, if you are careful with the punch it isn't even noticeable. This is an old trick I had seen for loose sleeve bearings on a lawn mower wheel.
JimC
Oconomowoc, Wisconsin
« Reply #16 on: March 15, 2010, 07:51:48 PM »
If you want a de-smog kit that will not blow out, and looks like part of the factory block, check out Darryls kit;
http://www.xf6-custom.com/partpages/desmog.html
I used his plugs, and when installed, they fit flush with the motor casting, and they fit so tight you actually have to look for the seam around the plug to see it. I would be willing to bet a months pay check that they will never blow out. Another part of his kit is a machined plate and gasket that eliminates what some guys have been doing, (breaking the tube and bending it over, or plugging it with jbweld) In my opinion his kit makes for a much more professional job.
Jim
Jim Callaghan
Oconomowoc, Wi
Jim Ross
Nevada&Idaho
« Reply #17 on: March 15, 2010, 09:11:38 PM »
Big BF does a de-smog......anyone know what kind of plugs he uses?
El Cazador, VRCC#1002
Black 98 Valk tourer,4 deg.TW,VikingExhaust,Progressives,RattleBar goodies,Ams/Oil,more chrome!
'94 Toyota 4WD P/U;
'01 Dodge2500,Cummins,RegCab,4WD,AMSOil, lightly souped up;
'07 Dodge3500, 5.9Cummins,RegCab,4WD,AMSOIL, stock---so far;
'10 GMC Terrain AWD V6.
X Ring
VRCC #27389, VRCCDS #204
South Mississippi
« Reply #18 on: March 16, 2010, 07:26:02 AM »
Hogdaddy, I got mine from a machine shop that rebuilds engines.
Marty
Hogdaddy
« Reply #19 on: March 16, 2010, 09:00:21 AM »
Marty, Thanks
I called over a dozen autoparts, machine shops etc. I called the last Autozone today. The lady said she had some and if I wanted all they had I could have them for a penny each, so I now have about 20. Do you put anything on them before you drive them in?
Hogdaddy
matt
Derry New Hampshire
« Reply #20 on: March 16, 2010, 03:05:21 PM »
i have hit all parts houses that i deal with as i am in the auto repair busness and they all laugh when I ask for 14mm plugs    today I read they are 9/16  is that correct?  also I would rather not put anything over them as it seams majority do not blow.  next question do you put them flush or drive them to the bottom
Thunderbolt
« Reply #21 on: March 16, 2010, 03:31:13 PM »
the 9/16 is what I am referring to.  I drove mine all the way down, then mixed up some of the epoxy that comes in a roll with two colors and you knead it together and pressed it in.  I have Kuryakyn valance covers so you can't see this anyway.  If I did not have the covers, I probably would have looked for some chrome caps to put on the top of the epoxy.
Use a small socket, one that fits loose on an extension.  If you use one that fits snug, you won't be able to get it out once you tap it to the bottom as the top rolls over a little.
X Ring
South Mississippi
« Reply #22 on: March 16, 2010, 07:37:12 PM »
Didn't put a thing on mine and drove them in till they bottomed out.  On the bottom of the engine I made blockoff plates.  Scribed the outline of the fittings on 1/8" aluminum, applied black hi temp silicone to the engine side and used the fitting with the tube cut off to secure plate in place.
Marty
matt
Derry New Hampshire
« Reply #23 on: March 17, 2010, 07:55:52 AM »
once again thanks for all your input   I am happy I found the vrcc as I have recieved some good help  no the fun part putting the air box back on  going to try Dags way
