TBR Quick bags vs Rattlebars Bag Drop kit vs other
<< < (2/2)
Garland:
The TBR system is eight 1/4" x 1" type "M" stainless quicklock pins.            http://www.bosunsupplies.com/products2.cfm?product=QRPinSuncor
Below are the installation instructions included with the kit:
Step 1: Remove the 4 bolts holding each saddle bag in place.
Step 2: Use 1/4 drill bit to drill out the threads from the bag mounting points. Use care to drill as straight a hole as possible.
Step 3: Set the bag back in posiition on the bike and insert each pin through the mounting hole while depressing the release button.
Step 4: After installing each pin it's a good idea to try to pull the pin out WITHOUT depressing the release button. This will insure a positive lock on each pin.
Step 5: Enjoy
I seem to remember the kit being about $200, but the pins are about $15 each-so about $120 all together.
SgtBunny:
I found another place for the pins at $10 ea: http://www.berkeleypoint.com/products/hardware/quick_lock_pin.html
I have read where some people notch their hardware in such a manner as:
http://www.valkyrieriders.com/shoptalk/tbrbag.htm
Has anyone done this and how well does it work.
Navigation
[0] Message Index
[*] Previous page
