January 30, 2026, 02:05:52 AM *
Author Topic: Are Wheel Dampers Common  (Read 4503 times)
mirion
1997 Std - 2000 IS
Frankenmuth, Michigan
« on: November 01, 2009, 08:09:34 PM »
Does anyone know if all years of Valkyrie rear wheel dampers are the same? HDL lists a slightly different part number for 97 and 99.
1999
DAMPER SET, WHEEL
06410-MBH-000
1997
DAMPER SET, WHEEL
06410-MZ0-A00
X Ring
VRCC #27389, VRCCDS #204
« Reply #1 on: November 01, 2009, 09:12:19 PM »
My understanding is the later set includes the metal inserts while the '97 & '98 doesn't.  You have to buy them seperately.
Steve K (IA)
Cedar Rapids, Iowa
« Reply #2 on: November 01, 2009, 09:32:49 PM »
Yes, just play it safe and get the ones for a year 2000.  If you get them for earlier years it will be something like $80 compared to $32.  The earlier years you would have to get the rubber and the aluminum inserts separate to make them complete.  Don't ask me how I know this.
States I Have Ridden In
Airetime
Anacortes, WA
« Reply #3 on: November 01, 2009, 09:38:49 PM »
1999
DAMPER SET, WHEEL
06410-MBH-000
1997
DAMPER SET, WHEEL
06410-MZ0-A00
Do yourself a favor and upgrade those wheel dampers. Here is a link so that you can contact him and see if he is going to make any more.http://rattlebars.com/cart/bushings.html
They are usually a special order item but worth the wait.
« Last Edit: November 02, 2009, 05:30:29 AM by Airetime » Logged
mirion
1997 Std - 2000 IS
« Reply #4 on: November 02, 2009, 09:05:58 AM »
Thanks for the info guys. I am buying a set for a 97 bike with a 99 wheel and wanted to understand why the different numbers but that would explain it.
X Ring
« Reply #5 on: November 02, 2009, 11:24:18 AM »
Just about everything else.  Just make sure you transfer the brake rotor to the 99 wheel to prevent possible interference issues.
Marty
woefman
Arizona
« Reply #6 on: November 18, 2009, 03:41:32 AM »
What are the symptoms of a bad Damper ?
Lot of Back Lash I suspect ?
Honda` GL1800 Goldwing
Honda` GL1500 CT Valkyrie
Picture Links below:
http://picasaweb.google.com/azpicts
and
http://picasaweb.google.com/azpicts2
Wildman
« Reply #7 on: November 18, 2009, 05:18:25 PM »
The sign of worn dampners is more back-lash.
If you engine is not running perfectly smooth you wil notice the back-lash the most in first gear. With your engine at no load and your bike speed matching your idle RPM. Any variation in engine RPM causes the drive line to go from pulling to pushing very quickly you will hear the lash as long as the engine and wheel speed matches and you are in a no engine load situation
If you want to grt rid of the drive line slop, while your new dampners are on order, you can use wooden slats just a tiny bit thicker than the space between the dampners and the whel dampner pockets.
It works best if the slats are a bit thicker than the space and you tilt the dampners up on the short side from the stud then slide the slat and the dampner back into the pocket.
I've been riding with slats for the last 4K miles they work well.
I need to get the urethane dampners, the OEM's waer out too fast.
Shockbushing Gary
« Reply #8 on: November 19, 2009, 06:37:33 AM »
Edit: SOLD
I have 1 set left from the last batch molded.
First $75 ($78 via Paypal) gets 'em.
« Last Edit: November 20, 2009, 05:48:26 AM by Shockbushing Gary » Logged
Momz
ABATE, AMA, & MRF rep.
« Reply #9 on: November 19, 2009, 07:52:12 AM »
Garys wheel dampers are the best you can get.  Trust me, I've had to replace my OEMS twice on my I/S.
The less slop due to the dampers, the less wear on your drive splines. Oh,...use Gaurd Dog Moly 525 on the pines and the splines along with new O-rings for the greatest way to extend the driveline life.
ALWAYS QUESTION AUTHORITY!
Larry
Northeastern BC, Canada
« Reply #10 on: November 19, 2009, 08:05:56 AM »
+1 on Gary's dampers.  cooldude
