February 14, 2026, 03:09:57 AM *
Author Topic: Audiovoxx (Murphs kit) Cruise Install - Vac line question  (Read 1626 times)
txtriathlete
« on: March 18, 2018, 01:46:48 PM »
Where do the vacuum lines tie into the carbs? Following the shoptalk "how to" but there is no discussion of where to connect the lines.
« Reply #1 on: March 18, 2018, 02:12:42 PM »
On the intake manifolds.
« Reply #2 on: March 18, 2018, 04:34:36 PM »
Little tubes sticking out in back of the carb intakes, the usable ones will just have a small rubber cap and spring clip on them.
semo97
Texas
« Reply #3 on: March 19, 2018, 05:51:24 AM »
if you have de-smoged you will have 5 lines to use if you have also went with a non vacuum on off gas valve like a pingel you will have 6 lines you can use. When I did my IS I used all of them. I went three into one for each side then two into one that went to the canister.
« Reply #4 on: March 19, 2018, 07:29:35 AM »
I used to have all six feeding the vacuum reservoir, seemed like a lot of hoses to me which means vacuum leaks sooner or later. A couple years ago I changed over to using just one from each side and the CC holds fine. Some riders don't even use a reservoir and have good response.
txtriathlete
« Reply #5 on: March 21, 2018, 07:12:08 AM »
Good info, thanks. Went ahead and did the desmog while I had it apart and got familiar with all the hoses etc. in there. using the "How To" in Shop talk so setting up as 5 into the reservoir. We will see how it holds up. I can always cut that stuff out later if it gives me a problem.
Related but different question - looks like there are carb overflow hoses attached to the bottom of the carbs that manifold together and route to the back of the engine. Are these necessary? Seems like a lot of plumbing. I can't see that they do anything except maybe drain?
« Reply #6 on: March 21, 2018, 07:42:11 AM »
Yes, they are bowl drain lines. I removed them from my Standard.
