February 14, 2026, 03:10:01 AM
Coolant leakage
Topic: Coolant leakage (Read 1020 times)
32coupe
Retired Air Force Colonel
Weatherford,Tx
Coolant leakage
March 19, 2018, 09:40:44 AM »
My 99 Standard has a coolant leak somewhere. Not frequent, but about once every 2 months I notice a couple of drops of coolant on the floor, underneath the left front area of the bike. Some artivles say the water pump is bad and needs replacement. Others say that tow small hoses connecting the radiator are leaking. Any consensus on what my problem could be?
Witness
3-19-18
Witness
Re: Coolant leakage
March 19, 2018, 10:06:18 AM »
The T'Stat housing has the top radiator hose connection. That clamp is famous for being loose. A long screwdriver will often reach it. If not, the radiator will have to be tilted forward.
Whiskey Bravo
Re: Coolant leakage
March 19, 2018, 10:19:15 AM »
Hello, and speaking only from personal experience…
I would further recommend changing the clamp completely with one which is wider… Tightening the original clamps usually is a Band-Aid fix and will eventually start leaking again
However, if you replace the entire clamp with a wider one available at any local parts store… this solves the problem
Hope this helps
Yours truly,
Whiskey bravo
