February 14, 2026, 03:09:51 AM *
Author Topic: Start Sw. Relay Mod Question...But...  (Read 1014 times)
mrgeoff
My 99 CT..."Liahona"
Augusta, GA.
« on: March 23, 2018, 07:19:19 PM »
Ok, I have a 99Tourer and want to install the Relay Mod for the Headlight/Start Sw...I am also installing the SignalBoss too...I have a question...Should I install the Relay Mod first and then hook up the SignalBoss?...This seems like the proper way for me...Now, should I use the 4 pin relay(85,86,87,30/51terminals) 0r the 5 pin(87a)...? Also,  what color wire should I connect to 86 and 87(is it the bl/w)?...and then just connect the R/Blk(Hot) wire to 30/51 terminal...Huh? and use 85 to Grnd...Huh?...These will be the original wires from the Headlight enclosure...I know after I get this working, I will install the SignalBoss...!!! I did the Mod when I had my 06 VTX 1800R, but I sold it and bought the Valkyrie and I just can't seem to get this simple Mod thru my head...am I going to find the same color wires in the Valkyrie Headlight as in the VTX 1800R Headlight?? Any help would put me at ease...Thanks...!!!
mrgeoff/SANDMAN
« Reply #1 on: March 23, 2018, 08:06:09 PM »
I've never heard of the SignalBoss, how about a link?
« Reply #2 on: March 23, 2018, 08:11:58 PM »
For the relay, open the link and scroll down the box labeled Start Switch Safeguard and follow the directions. It has the pin #'s, wire colors....the whole thing. Clear as can be.
http://www.rattlebars.com/mtz/starter.html
mrgeoff
Augusta, GA.
« Reply #3 on: March 23, 2018, 08:47:04 PM »
Thanks John...I just thought it was the same...Thanks...Gordonv, (Jersey) has made a plug and play that turns bike turn signals  into escort and warning lights...
Autocancel, Hazards & Escort Flashing...you can get in touch with him...!!!
mrgeoff/SANDMAN
« Reply #4 on: March 24, 2018, 07:49:42 AM »
I took a different route and got chromed controls and reservoirs in the process. I adapted HD controls to my Valk, with those controls you have separate buttons for turns signals. With that, I was able to install a module that gives me three different lengths of time for my turns, 4-ways, and brake interruption of the time out. And, if I want to cut the flash short, just click that button again and it goes off. Have had it on the bike for quite a few years now with nary a minute of trouble. Only challenge was creating a double relay setup to kill the headlight when starting, an easy job. And since I lost(thankfully) the lousy choke control on the left side, I created a better system for the choke and it has been solid since installed.
« Last Edit: March 24, 2018, 07:55:58 AM by John Schmidt » Logged
