February 14, 2026, 03:09:49 AM *
Author Topic: battery draw  (Read 1649 times)
savy265
« on: March 29, 2018, 05:17:49 PM »
i  have  a  2000 interstate, my  battery  will  go  dead  after  4  days. i  checked  out  why  and  i  have  about  a 500 ma draw.  Is  this  normal,?    tks  bob
WintrSol
Florissant, MO
« Reply #1 on: March 29, 2018, 06:40:31 PM »
The leakage test in the service manual says leakage should be less than 0.1mA, but this is for the standard. It doesn't address any keep-alive current for things like a clock or radio, but 500mA seems excessive. I'd say you should hook up a battery tender, and try to find what is drawing all that power.
oldsmokey
Mendon Massachusetts
« Reply #2 on: March 30, 2018, 04:43:13 AM »
Just how good is the battery?  Maybe isolate it,  give it a good charge then load test after it rests a  little while.
WintrSol
Florissant, MO
« Reply #3 on: March 30, 2018, 06:42:02 AM »
Sounds to me like a very good battery, since it should be 14Ah, and a 1/2A load for one day would be 12Ah, so it should be dead in just over one day. Of course, going flat like that will weaken any battery, until it IS bad.
« Reply #4 on: March 30, 2018, 07:23:59 AM »
Remove fuses one at a time till the draw goes away. Then find out why.
indybobm
Franklin, Indiana VRCC # 5258
« Reply #5 on: March 30, 2018, 05:17:02 PM »
Anything directly connected to the battery? Added accessories? GPS?
So many roads, so little time
VRCC # 5258
savy265
« Reply #6 on: March 30, 2018, 05:38:25 PM »
there  are  two  things  connected  , a  l.e.d  light and a  security system. those  have  separate eye  hook  connectors, isolated  them  ,the  both  show  no  current  draw. Battery  is  good  tested after  a  full  charge. i;ll  keep  ya  posted , i  will  disconnect  fuses to  pinpoint  the  issue,  i  do  keep  the  bike  on  a  tender since  i found  this  out, tks  bob
da prez
Wilmot Wi
« Reply #7 on: March 31, 2018, 11:20:29 AM »
With the battery fully charged , disconnect the battery and check the voltage. Leave un hooked for at least 24 hours. No charger or draw. Re check voltage. If lower , internal short. Make sure battery is clean. I have recorded voltage loss across a dirty battery.
             da prez
savy265
« Reply #8 on: April 01, 2018, 04:25:14 PM »
the  draw  is  from  the  audio  system,   2 amps  at 7 volt draw  ,so  for  now  i  took  the  15  amp  fuse  out. now  its 00.1 ma  draw. i  can;t  find  a spec  with  radio,cb draw in  my  book.
WintrSol
Florissant, MO
« Reply #9 on: April 01, 2018, 05:42:11 PM »
Does removing the Audio Main Relay have any effect, with the 15A fuse installed?
savy265
« Reply #10 on: April 02, 2018, 04:14:49 PM »
it  has  no  effect, it  is  on  a  different circuit i  found  spec  on  a  bike  with  no  radio,  but  nothing  on how  much  the  system  will  draw.i  know  there  should  be some.memory for  clock, radio  presets  and  all  ur  inputs  tks
Ken aka Oil Burner
Mendon, MA
« Reply #11 on: April 02, 2018, 06:14:45 PM »
There should be some minor draw for presets and memory, but 2 amps is WAY too much. As an auto tech, ignition-off draw is measured in milliamps. Allowable used to be around 25mA a few years back, but has been increased due to the insane amount of modules in some vehicles to around 60mA or so (varies by manufacturer). A motorcycle should be far less. Short in the audio unit itself? Any abnormal audio operation?
Steel cowboy
Spring Hill, Fl.
« Reply #12 on: April 03, 2018, 03:47:03 AM »
How new is the bike to you? If the draw is from the audio circuit there might be an amp installed.
2001 black interstate
2003 Jupiter Orange wing
indybobm
« Reply #13 on: April 03, 2018, 05:33:17 AM »
And if there is an amp installed, the amps power wire should be connected to a key-on source, not hot all of the time.
VRCC # 5258
savy265
« Reply #14 on: April 04, 2018, 05:08:57 PM »
bought the  bike  in  October , never  rode  it  intill  last week.i  have not  seen  a  amp,  only  has  two  added  wires  and  they  have  no  draw.
Avanti
Stoughton, Wisconsin
« Reply #15 on: April 04, 2018, 11:05:26 PM »
Might try checking for a stuck relay.
WintrSol
Florissant, MO
« Reply #16 on: April 05, 2018, 08:25:30 AM »
That's why I asked about the other relay - it provides power to the controls, which should turn the radio on/off. If the relay is inside it, though, maybe tap on the case - the 'old school' percussive maintenance trick.
savy265
« Reply #17 on: April 05, 2018, 02:11:44 PM »
tks  for  the  advice
