November 14, 2025, 09:54:28 PM *
Author Topic: Cobra Light-bar and Memphis "Fats" Windshield  (Read 1386 times)
954rocks
« on: April 07, 2018, 09:29:24 AM »
I have a 2003 Valkyrie Standard with a Cobra Light-bar and would like to mount a Memphis Fats - 19" Tall x 22" Wide x 9" Headlight Cut-out windshield but am concerned about interference with the passing light housings. Anyone have experience with this set-up..?
DarkSideR
Pueblo, Colorado
« Reply #1 on: April 08, 2018, 07:12:08 AM »
I have both on my bike and there are no issues.
2001 Valkyrie Super Tourer
VRCC#34410
VRCCDS#0263
954rocks
« Reply #2 on: April 08, 2018, 09:53:59 AM »
Thanks Darksider ! Are those Memphis lowers you have there?
DarkSideR
Pueblo, Colorado
« Reply #3 on: April 08, 2018, 10:07:43 AM »
No, those are Rifles. And they did have to be notched to fit with the light bar.
VRCC#34410
VRCCDS#0263
« Reply #4 on: April 08, 2018, 11:12:57 AM »
I think you would be alright with the Memphis lowers. They stick out a little further than the rifles. They might shade your turn signals though.
« Reply #5 on: April 08, 2018, 12:34:33 PM »
Why didn’t you use the adapters to properly mount the blinkers to the Cobra bars?
DarkSideR
Pueblo, Colorado
« Reply #6 on: April 08, 2018, 01:04:26 PM »
The blinkers hit the Lowers.
VRCC#34410
VRCCDS#0263
Kokomo Kevin
Kokomo, Indiana
« Reply #7 on: April 08, 2018, 02:04:06 PM »
Darksider,
           Nice looking set up, Can I ask what lights are you running in the Headlamp and light bar?
Are they easy to install?
                            Kokomo Kevin
DarkSideR
Pueblo, Colorado
« Reply #8 on: April 08, 2018, 02:11:29 PM »
Darksider,
                            Kokomo Kevin
Thank you. They spots are DayMaker LED's. I got them from Scootlights.com. I had to modify the lights wiring harness but otherwise they were easy to install.
VRCC#34410
VRCCDS#0263
kc5tf
« Reply #9 on: April 09, 2018, 07:02:36 PM »
I would like to install the headlight you have can you tell me the cost and where you bought.
DarkSideR
Pueblo, Colorado
« Reply #10 on: April 09, 2018, 07:22:37 PM »
The main headlight was also purchased from scootlights.com. It is the Aurora Half Halo. To install it you will need an adapter bracket. Lucky for you I am the guy who manufactures and sells the adapter brackets. Email me ValkyrieJosh@gmail.com with your shipping address for a quote.
« Last Edit: April 10, 2018, 06:02:33 AM by DarkSider » Logged
VRCC#34410
VRCCDS#0263
« Reply #11 on: April 10, 2018, 06:00:23 AM »
The main headlight was also purchased from scootlights.com. It is the Aurora Half Halo. To install it you will need an adapter bracket. Lucky for you I am the guy who manufactures and sells the adapter brackets. Email me ValmyrieJosh@gmail.com with your shipping address for a quote.
Josh, I think you have a typo.  Smiley
DarkSideR
Pueblo, Colorado
« Reply #12 on: April 10, 2018, 06:02:58 AM »
Thank you sir. Fixed.
VRCC#34410
VRCCDS#0263
Kokomo Kevin
Kokomo, Indiana
« Reply #13 on: April 10, 2018, 06:18:41 AM »
Darksider, Do you need a bracket for the spot lights as well?
                 Kokomo Kevin
DarkSideR
Pueblo, Colorado
« Reply #14 on: April 10, 2018, 07:31:55 AM »
                 Kokomo Kevin
No. But I did have to modify the spots wiring harness. There wasn't much room in the Cobra's buckets. So I cut off the connector, and removed the thick rubber so that the 2 wires were left. I then soldered the positive and ground connections in the bucket, and finished with heat shrink. Lastly I used a small piece of foam behind the light to keep it pressed in place, whereas the clip used for the standard Halogen bulb won't work.
VRCC#34410
VRCCDS#0263
Kokomo Kevin
Kokomo, Indiana
« Reply #15 on: April 10, 2018, 08:30:51 AM »
Thanks for the info! How much for the headlight bracket, if I decide to make the change?
                     Kokomo Kevin
DarkSideR
Pueblo, Colorado
« Reply #16 on: April 10, 2018, 10:09:15 AM »
                     Kokomo Kevin
The bracket is $65.00 + shipping.
VRCC#34410
VRCCDS#0263
Kokomo Kevin
Kokomo, Indiana
« Reply #17 on: April 10, 2018, 04:48:46 PM »
Thanks, So looking at your setup and looking at Scootlights looks like $300  to get the same
setup you have. Let me think about it. I like the LED setup, I have them on my F6B and they
make a huge difference on seeing and being seen. Question have you done a tailight LED mod
by chance as well?
                 Kokomo Kevin
DarkSideR
Pueblo, Colorado
« Reply #18 on: April 10, 2018, 05:12:33 PM »
by chance as well?
                 Kokomo Kevin
Not yet. Tail lights and turn signs are next.
VRCC#34410
VRCCDS#0263
DarkSideR
Pueblo, Colorado
« Reply #19 on: April 10, 2018, 05:21:04 PM »
by chance as well?
                 Kokomo Kevin
I should mention that it is a cost savings upgrade. The DayMakers will out last the life of over 14 halogen bulbs. Couple that with you being seen better and it kind of becomes a no brainer.
VRCC#34410
VRCCDS#0263
Kokomo Kevin
Kokomo, Indiana
« Reply #20 on: April 10, 2018, 06:34:33 PM »
Yep, Let us know when you do the tail/turn lights, would like to see pictures, thanks cooldude
             Kokomo Kevin
