March 31, 2026, 10:15:47 AM *
Author Topic: with only an estimated cost of $40,000 per mile  (Read 967 times)
« on: April 10, 2018, 04:25:32 PM »
http://www.foxnews.com/us/2018/04/10/los-angeles-painting-city-streets-white-in-bid-to-combat-climate-change.html
DirtyDan
Kingman Arizona, from NJ
« Reply #1 on: April 10, 2018, 04:27:16 PM »
Boondoggle anyone ?
Dan
97BLKVALK
VRCC#26021
Detroit Lakes, MN
« Reply #2 on: April 10, 2018, 04:35:42 PM »
I wonder which politicians relative owns that company.  I would like to see the roads after a year to see the reflective quality and how much is lost due to black tires, oil and emissions. Each coat is pricey at $40,000 but each section of road takes two coats therefore approximately $80,000 per mile.
Someone is banking some cash.
Next will be white rubber tires
Michael
« Last Edit: April 10, 2018, 04:46:23 PM by 97BLKVALK » Logged
1997 GL1500C - Black
1997 GL1500C - Purple
1997 GL1500C - Bumble Bee
1998 GL1500C - Blue and Cream
Pete
« Reply #3 on: April 10, 2018, 04:37:30 PM »
Obviously they have not discovered concrete instead of ..................
« Reply #4 on: April 10, 2018, 05:03:33 PM »
the labor cost too high compared to oil based asphalt, which also provided worst mpg compared to concrete.
a few yrs ago, that state wanted to ban all black vehicles from being sold there, for same reason heating up the climate.
« Reply #5 on: April 10, 2018, 05:54:04 PM »
Great for "street artists!"
« Reply #6 on: April 10, 2018, 05:55:54 PM »
"applied in two coats, each 50 microns thick,"
Did ya see the guys in the photos using highly technical equipment to ensure the correct paint depth  Grin
« Reply #7 on: April 10, 2018, 07:53:17 PM »
Years ago, I got a wild hair to stain (paint) my sidewalks since they were aging and not looking too good (but I sure wasn't going to pay for new concrete).  I did a good job, and boy did they look great, for about 18 months when half of it came off and the spotty polka-dot look was far worse than I started with.  And the parts that didn't come off, would not come off for years.
And my sidewalks probably got a lot less use than LA streets will.
What complete nonsense.
Hey, if white streets are good for the environment, what about white people, and..?   Oh man, don't go there.......
« Reply #8 on: April 10, 2018, 08:23:23 PM »
You nay sayers are wrong. This white pavement has already been proven to work. AZ is looking into it too. Both light and heat reflect in a similar manner. Pavement temps are much cooler when painted white. In the last 40 years, our average nighttime lows have gone up more than 11 degrees due to heat absorption of concrete and pavement.
« Reply #9 on: April 10, 2018, 08:58:45 PM »
But Sandy, is this being done to save the pavement... or the earth?
Or maybe cooling (AC/electricity) costs?
Psychotic Bovine
New Haven, Indianner
« Reply #10 on: April 11, 2018, 02:44:34 AM »
But, there have been studies showing that the energy emissions to produce the coating is far higher than the coatings will supposedly negate.  Also, the light reflecting back into the air can cause a decrease in cloud cover.
Do these streets cause eyestrain, similar to snow blindness?  just curious on that.
"I aim to misbehave."
RP#62
Gilbert, AZ
« Reply #11 on: April 11, 2018, 04:21:12 AM »
Sounds racist to me.  I think I am offended.
-RP
RudyF6
Chelsea, Michigan
« Reply #12 on: April 11, 2018, 04:27:02 AM »
There's just no end to the  crazy2 in CA, is there?
You can never be lost if you don't care where you're going!
98 "Tourerstate" (Std. with I/S bags/trunk)
98 Tourer solo ride
81 CBX
Sorcerer
Brooklyn Center MN.
« Reply #13 on: April 11, 2018, 05:23:34 AM »
Any one thought about motorcycle tires, even car tires on wet (rain) painted streets.
« Reply #14 on: April 11, 2018, 05:48:17 AM »
It's supposed to be grippy.  Roll Eyes
« Reply #15 on: April 11, 2018, 05:50:06 AM »
So stop putting down so much concrete and pavement. Really an easy fix.
Unless taxes are needed to pay for the increase in population?
« Reply #16 on: April 11, 2018, 09:09:40 AM »
The cooler pavement reduces the heat island effect which reduces cooling costs. Dirt roads are better than every other choice. Do we want that?
« Reply #17 on: April 11, 2018, 09:32:18 AM »
I wonder if a cost-benefit analysis was ever done before it started going on the roads, or whether the decision-making was, "Someone said it will reduce global warming climate change, so whatever the cost, we're doing it!"
I've noticed that the black sealcoat used in parking lots is far more prevalent in the US than in Canada, and while it looks terrific, boy does it make for a hot parking lot!  I wonder how the long-term cost of the white stuff compares to the cost of the black stuff.  Perhaps a case could be made that only white sealcoat is permitted, where sealcoat is used.
« Reply #18 on: April 11, 2018, 05:39:46 PM »
absofrikinlutely NONE/ZERO/NADA do NOT even ask fed money for this white wash! RIDE SAFE.
