November 14, 2025, 08:20:51 PM *
Author Topic: Block Drain  (Read 950 times)
Jruby38
Oxford Mass.
« on: April 11, 2018, 12:57:01 PM »
I just replaced my water pump and drained coolant from the drain plug. I noticed a T55 plug on the left side of the motor just behind the water pump and I wonder of it is a block drain. Has anyone removed that plug?
« Reply #1 on: April 11, 2018, 07:45:12 PM »
I'm not sure which one you are indicating exactly, but there was a post within the last two years someone opened the wrong bolt and only got a little out. Then was redirected to the correct one.
