March 31, 2026, 10:12:57 AM *
Author Topic: Thule Compact Bike Trailer for Members who like to Weld/Fabricate  (Read 996 times)
Alberta Patriot
« on: April 14, 2018, 01:15:08 PM »
Bored and needed to keep my mind occupied/sharp, so I did this up on Sketchup
The Thule Car Topper is based on the "Sidekick"  Specs... 54" L, 25" W and 16" D
16 pounds empty with a 110 pound maximum load capacity.
Torsion Axles are based on the 425 pound per pair max load Flexiride half axles with 8"x 5 lug rims
Total length-about 65"   Total Width-about 36" Total Height-about 25"
I think it would probably end up around 100 pounds total...around 225 pounds loaded.
https://www.ebay.com/itm/Thule-682-Sidekick-Roof-Box/323060267793?epid=1322955902&hash=item4b37e47b11:g:zDQAAOSwExlae5E3&vxp=mtr
https://www.northerntool.com/shop/tools/category_tires-wheels+high-speed-trailer-tires-wheels+8in.-high-speed-trailer-tires-wheels
https://www.easternmarine.com/flexiride-torsion-half-axles-ff-425-2a-s
« Last Edit: April 15, 2018, 09:21:20 AM by 7th_son » Logged
« Reply #1 on: April 14, 2018, 01:26:55 PM »
Enlarge those wheels to 12" and you have a very solid trailing trailer. If I had an option and was building for myself I'd go with 12". Otherwise looks great.
Alberta Patriot
« Reply #2 on: April 14, 2018, 01:32:39 PM »
The thought was as low a C of G as possible with the 8" rims, and I guess with the adjustable swing arms it would be easy to lower the whole thing for 12" rims anyway.
« Last Edit: April 14, 2018, 02:25:12 PM by 7th_son » Logged
« Reply #3 on: April 14, 2018, 03:28:18 PM »
I think you'd have to use 12" wheels. I've never seen 8" wheels with 5 lugs. 12" wheels can be had in both 4 & 5 lug.
Alberta Patriot
« Reply #4 on: April 14, 2018, 04:53:09 PM »
I guess you didn't look at the link to the wheels
« Reply #5 on: April 15, 2018, 04:12:13 AM »
I like it.  I agree with those suggesting larger wheels/tires, I don't see the height being a huge issue.
But, when I consider how much my older trailer cost (purchased used)'and how much it gets used, I can't see building one costing more than twice as much.     But, I do like the concept and the design.
Currently, I'm trying to find an old junk RV (fifth wheel or gooseneck) trailer to rebuild into a specific purpose utility trailer.   So, I like doing such projects.  Keeps the mind and body active.   Smiley
« Last Edit: April 15, 2018, 07:50:39 AM by Rams » Logged
Bigwolf
Cookeville, TN
« Reply #6 on: April 15, 2018, 09:05:00 AM »
That looks like a really nice trailer.  I too would go with 12 inch wheels.
Bigwolf
Alberta Patriot
« Reply #7 on: April 15, 2018, 09:17:33 AM »
Yep...12" rims would give you many aluminum trailer wheel options that are not available with the 8" ones. With a light trailer like this you want to keep un-sprung weight down to a minimum, like using 4.80-12 tires. Pretty sure they would last forever with a max 225 pound trailer.
« Last Edit: April 15, 2018, 09:23:51 AM by 7th_son » Logged
Bigwolf
Cookeville, TN
« Reply #8 on: April 15, 2018, 10:10:26 AM »
That is true.  However, I believe that there is a huge difference in the impact delivered when an 8 inch wheel hits a pot hole or bump vs a 12 inch wheel.  To me, it is worth the sacrifice in un-sprung weight.
Also, be very careful buying 4.80 - 12 tires.  Most of those are rated for UNDER 40 mph.
To me, something like Bushtec uses is ideal but man,....those wheels are expensive!
Bigwolf
« Reply #9 on: April 15, 2018, 10:23:33 AM »
Well shoot, if we're gonna go first class, then make it tandem axle, tilt bed with lots of lights......   Wink
Alberta Patriot
« Reply #10 on: April 15, 2018, 11:02:43 AM »
Diamond Plate Platform out back for the Cooler that holds a 24 Pack  cooldude
