February 14, 2026, 11:56:42 AM *
Author Topic: WILL THESE METAL VALVE STEMS WORK  (Read 1327 times)
Scottrtho
« on: April 15, 2018, 06:48:25 PM »
Going to order some tires from here, so I thought I would replace valve stems too. I bookmarked the ones available on ebay that have the nut inside of the rim, but wondered if these also fit and have anybodys belssings? Also pros/cons on beads vs goop to balance tires.
Thanks. Scott
http://www.chaparral-racing.com/product/bikemaster-90-chrome-valve-stem/310-03-029.aspx
« Reply #1 on: April 15, 2018, 07:57:54 PM »
Most like these,
https://www.ridersdomain.com/motorcycle-tires/myers-90%C2%B0-tubeless-chrome-valve-stem-p
With the nut on the out side.
Used to be Jake Wilson, now under the above named business.
They used to have quarterly sales, no shipping.
« Last Edit: April 15, 2018, 07:59:35 PM by gordonv » Logged
Scottrtho
« Reply #2 on: April 15, 2018, 11:32:30 PM »
Thanks...just ordered a pair. Still seeking advice on wheel balancing.
« Reply #3 on: April 16, 2018, 06:46:57 AM »
Use dyna beads or BBs.
« Reply #4 on: April 16, 2018, 06:57:49 AM »
I use Ride-on.  Adds a little peace-of-mind about potential punctures in the centre of the tread, and no issues with blocking the valve stem open when checking tire pressure, as some have experienced with balance beads.
« Reply #5 on: April 16, 2018, 07:41:55 PM »
Was that in another post?
I just mounted 2 dual roller bearings in my new to me rear rim, for the rear bearing mod.
http://www.valkyrieriders.com/shoptalk/5204_bearing_mod.pdf
It didn't have any bearings, so I went with the 2 dual instead of the OEMs.
Lyle Laun
Calgary, Ab
« Reply #6 on: April 17, 2018, 05:25:21 AM »
I'm with Gryphon Rider and use the Ride On balancer & sealant. I've been using the one that they sell for atv's (it's cheaper) and haven't had any issues.
Lyle
Get out & Ride !!
98 Black "Rat Rod" Standard
99 Green/Silver Interstate
« Reply #7 on: April 17, 2018, 07:08:42 AM »
Lyle
Have you found a source in Calgary?  Last time I got mine was in 2015 in Montana.
Motodad71
Westerville OH
« Reply #8 on: April 17, 2018, 06:03:57 PM »
Ride-On is awesome stuff.....YES it works as advertised.
1997 yellow/black Valkyrie standard "Thor"
mrgeoff
My 99 CT..."Liahona"
Augusta, GA.
« Reply #9 on: April 17, 2018, 07:06:17 PM »
What ever 90* valve stem you buy, make sure that there is a rubber seal on both sides of the rim when it is mounted...will never leak if installed properly...Also I highly recommend Ride-On over Dyna beads or any type of beads...!!! IMO...!!!
mrgeoff/SANDMAN
« Reply #10 on: April 18, 2018, 06:10:00 PM »
I just use wheel weights for balancing clipped onto the rim.  OLD school... laugh
Gabriel
Near Galveston
« Reply #11 on: April 18, 2018, 06:15:11 PM »
I have some of these coming in the mail;
https://www.ebay.com/itm/2-x-Universal-Tubeless-Tire-Valve-Stem-Bent-90-degree-for-Scooter-ATV-Motorcycle/112075842761?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m2749.l2649
« Reply #12 on: April 18, 2018, 06:16:39 PM »
Yup, and less $$$ also. cooldude
