February 14, 2026, 05:01:18 AM *
Author Topic: Feels like I’m running out of gas.  (Read 1869 times)
Jims99
Ormond Beach Fl.
« on: April 23, 2018, 04:45:32 AM »
Went on a ride Sunday, in between the rain, bike rain great. Left the restaurant and about 2 miles in felt like I needed reserve. I was about 20 miles from normal reserve time. No change, got to station and filled up. Took about 1/2 mile and it cleared up. About 2 more miles and did it again. Just headed home and parked it. I pulled a few plugs and they looked fine. Going to change them all later today and see if that helps. As I thought about it, do you think maybe water in gas? I never did hit any rain, and I ride at least once a week. First 20 miles was fine. Could the petcock not be opening all the way? Vacuum lines are still flexible, going to try and shoot with starting fluid to see if any vacuum leaks.
Any other things to check? Bike only has 55000 miles and I have taken good care of her. Only have 4 days till leesburg bike feast. Any suggestions would be appreciated. Thanks. Jim
99 tourer
00 interstate
97 standard
91 wing
78 trail 70
« Reply #1 on: April 23, 2018, 04:51:32 AM »
Can be a sign of a petcock problem.
Could be a vent problem... the hose at the tail end of
the tank is the vent hose... maybe you could pull over
when the problem arises and open the tank, see if it
sounds like you're releasing a vacuum...
Hooter
S.W. Michigan
« Reply #2 on: April 23, 2018, 04:58:11 AM »
Or, if you suspect possible water, dump about a half can of Sea Foam at it and see if the problem goes away. You don't have to ride in the rain to have water in the gas. Non ethenol gas (if that's what you are using ) can do that on its own.
Jims99
Ormond Beach Fl.
« Reply #3 on: April 23, 2018, 05:05:33 AM »
Thanks Mike , I did try that, no vacuum sound. I did have petcock vacuum shutoff fail one time about 8 months ago, never happened again. It is the stock valve and I do manually shut it off most of the time I park for more then a day, but not when I’m going place to place. Haven’t had any problems with it since. I have thought about a rebuild just to be safe.
99 tourer
00 interstate
97 standard
91 wing
78 trail 70
« Reply #4 on: April 23, 2018, 05:08:59 AM »
Sounds exactly like what mine did when the fuel valve started going bad.
« Reply #5 on: April 23, 2018, 05:09:28 AM »
I think a petcock rebuild is in order. I would also check that your tank vent line has the "T" in it. If it doesn't, water from the road can get sucked in and block the vent.
Jims99
Ormond Beach Fl.
« Reply #6 on: April 23, 2018, 05:13:31 AM »
I do run Seafoam once in a while just for that reason, but it may have been a while since last time. I’ll throw some in before heading to work and see if that helps.
All these responses so fast, want to skip work and try them.
Thanks. I’ll repost anything I find this evening.
99 tourer
00 interstate
97 standard
91 wing
78 trail 70
Bagger John - #3785
« Reply #7 on: April 23, 2018, 07:13:12 AM »
Ditto.
Two times.
Once was just a tiny leak - was able to get home, albeit on back roads. The second time saw the diaphragm fail in such a manner that I lost all fuel flow.
There's another petcock on my dining room table at the moment. When the bike in question comes out of winter storage and I run enough of the tank through, I'm going to modify the spare petcock to eliminate the vacuum plumbing and swap the existing one with it.
Tfrank59
'98 Tourer
Western Washington
« Reply #8 on: April 23, 2018, 07:18:14 AM »
Question: had your bike been sitting a while before that ride?  sounds like could be bad gas to me, or a clogged fuel system.  try gassing up where you know the fuel is good (ethanol free?) and put some seafoam in there.  Go for a long ride (though not too far from home in case she dies on you ;-) and see if the problem abates.
-Tom
recman25
Tucson, AZ
« Reply #9 on: April 23, 2018, 07:20:50 AM »
   I don't want to hijack Jims99 question, but I just replaced my air filter. I now realize that the vent hose that was mentioned here is missing on mine. I have the 1" or so nipple on the tank but no hose. Where does it go, is it connected to anything etc? Not looking forward to taking that tank off again.
Dan
  1999 Valkyrie Interstate
  Tucson, AZ  formerly Jersey Shore
« Reply #10 on: April 23, 2018, 07:49:36 AM »
If someone will ride behind you and they smell raw gasoline rebuild petcock time. Just ask Tailgate Tommy. RIDE SAFE.
« Reply #11 on: April 23, 2018, 08:01:33 AM »
Jims99, please read the topic that I posted that addresses this problem:
Topic: Modifying the OEM fuel petcock to remove vacuum function  (Read 31690 times)
Wow, I just saw that my thread has been read 31,000 times!  If I had a nickel for each read, I could get the paint job I've always wanted!
« Reply #12 on: April 23, 2018, 08:51:08 AM »
Hey bud, please tell me you didn't say that.....at least not that color.  Grin Forgot to add....we used to call that a taco wagon!  Wink
Re. the petcock conversion, I don't recall the size needed but to convert one of mine some time ago I did what Grumpy does. He removes all the guts, then installs two different size o-rings(Viton), seals off the vacuum and weep holes and you now have a solid manual petcock that still uses the OEM control knob.
« Reply #13 on: April 23, 2018, 09:24:47 AM »
I believe you can slip a vent line on the nipple near the rear of the tank just by lifting it in back a couple inches without pulling it all the way off.  It just goes down.
recman25
Tucson, AZ
« Reply #14 on: April 23, 2018, 09:33:42 AM »
[/quote]
 Thank you!! I was hoping thats all I had to do!
Dan
« Reply #15 on: April 23, 2018, 10:45:13 AM »
My recollection is a little sketchy here, that vent line may be the one with the T fitting farther down (the other side of the T being empty), so that water can't be sucked up the line.
I don't know if the available Valk parts schematics pictures show this in enough detail, but you obviously want to reproduce this properly.
On the right, #s 31-32 (I think)
https://shop.procaliber.com/oempartfinder.htm?aribrand=HOM&arian=MOTORCYCLE#/Honda/GL1500CFA_(99)_VALKYRIE_INTERSTATE,_USA,_VIN%23_1HFSC410-XA000001/FUEL_TANK/GL1500CF-99-A/14MBYXE1AMBY4F1700AE
You can probably do this cheaper than OE parts (if you get the hose diameter right; 4.5mm?), but they are not that steep.
I think this vent line ends up being tied to (or close to) three total lines under the bike, including the wider plugged dragon drool tube (which is supposed to be plugged).
« Last Edit: April 23, 2018, 10:55:51 AM by Jess from VA » Logged
recman25
Tucson, AZ
« Reply #16 on: April 23, 2018, 03:16:26 PM »
  Thats great, thanks, and thanks for the illustration.
Dan
Lyle Laun
Calgary, Ab
« Reply #17 on: April 23, 2018, 04:38:50 PM »
Sounds like a kinked/plugged vent line
Lyle
Get out & Ride !!
98 Black "Rat Rod" Standard
99 Green/Silver Interstate
RonW
Newport Beach
« Reply #18 on: April 23, 2018, 05:19:49 PM »
his vent line isn't even thar.
2000 Valkyrie Tourer
recman25
Tucson, AZ
« Reply #19 on: April 23, 2018, 05:23:41 PM »
 I was afraid this would happen. My question about the vent line was separate from original poster.
Dan
« Reply #20 on: April 23, 2018, 05:25:12 PM »
There are 2 posters with problems. Recman doesn't have the vent line. Jims99 does, or at least he didn't state it was missing.
RonW
Newport Beach
« Reply #21 on: April 23, 2018, 05:26:47 PM »
Okay, glad we got that straightened out then.
« Reply #22 on: April 23, 2018, 07:07:24 PM »
Welcome.
One other nice pointer to help.  When not pulling the tank off (and having to unhook the petcock and gas line and vent, and tank sending unit on interstates), but only stretching all that stuff out to get under it in back, a short 2 X 4 on it's edge is about as far as the tank wants to come up still tied in to all that, and it's the perfect spacer to use when trying to work underneath (with both hands) by just raising the rear of the tank.  Do pull the seat (it's just a key turn).
The other item that comes in very handy working on bikes is one of those headband LED lights, even in daylight.  It's so much better than drooling with a mini mag lite in your mouth.
Jims99
Ormond Beach Fl.
« Reply #23 on: April 24, 2018, 06:24:00 PM »
Thanks. I’m going to try this tomorrow if I can’t find a rebuild kit at local dealer. Really appreciate all everyone’s help.
99 tourer
00 interstate
97 standard
91 wing
78 trail 70
Jims99
Ormond Beach Fl.
« Reply #24 on: April 24, 2018, 06:47:29 PM »
Update: tried new plugs and seemed to work, but then I sprayed starting fluid around vacuum lines and found the rpm’s went up around petcock. Couldn’t find any leaks on line, so hopefully getting a rebuild kit tomorrow. All symptoms seem to point to valve. Thanks
99 tourer
00 interstate
97 standard
91 wing
78 trail 70
« Reply #25 on: April 25, 2018, 04:36:34 AM »
You can use the search feature here to find people talking about
rebuilding petcocks, things to look out for, helpful tips and pictures
(unless they were on photobucket  Shocked ) ... are you getting the OEM
rebuild kit (16953-MBZ-B51) ?
I like this article in shoptalk, especially the easy test you can
do before reassembly to see if the vacuum function of the
petcock seems to be working after you install the rebuild kit...
http://www.valkyrieriders.com/shoptalk/petcock.htm
Jims99
Ormond Beach Fl.
« Reply #26 on: April 25, 2018, 09:38:45 AM »
Thanks hubcapsc
99 tourer
00 interstate
97 standard
91 wing
78 trail 70
