February 14, 2026, 05:01:17 AM *
Author Topic: Thread Size  (Read 1020 times)
Firefighter
Harlingen, Texas
« on: April 24, 2018, 03:56:35 PM »
I have striped out the threads of the bolt that holds the coolant bottle and left side cover. Anyone know the thread size so I can try to tap or heli coil. Partzilla fiche #  11.  Part # 90101-MNS-003. Ordered new bolt can probably figure it out then,, just trying to hurry!
2006 Honda Sabre 1100
2013 Honda Spirit 750
2002 Honda Rebel 250
1978 Honda 750
mrgeoff
My 99 CT..."Liahona"
Augusta, GA.
« Reply #1 on: April 24, 2018, 05:32:21 PM »
Don't know the thread size, but I have heard that some folks will place a small piece of wire into the hole and gently screw the bolt into the hole...it holds but don't over tighten it...Let us know what size tap you use when you re tap the hole...!!!
mrgeoff/SANDMAN
Avanti
Stoughton, Wisconsin
« Reply #2 on: April 24, 2018, 07:28:12 PM »
Check thread from other side, it is the same.
« Reply #3 on: April 24, 2018, 09:54:43 PM »
Take the bolt to Ace Hardware. They can check it for you.
semo97
Texas
« Reply #4 on: April 25, 2018, 01:54:13 AM »
Tap it with standard threads not metric it will be just a tad larger may not even need to drill.
Avanti
« Reply #5 on: April 25, 2018, 06:37:06 AM »
This is a special fastener not replaceable by a bolt.
« Reply #6 on: April 25, 2018, 05:00:57 PM »
I believe it's 1.25
