March 31, 2026, 07:46:14 AM
Painting my plastic wind deflectors?
Topic: Painting my plastic wind deflectors? (Read 706 times)
pocket aces
Tampa, Fl
April 30, 2018, 02:44:19 PM »
I painted my deflectors with a paint that bonds to plastic. They look good but they are not smooth and have some orange peel. Should I sand them now with a 1000 or 1200 grade then clear coat? Then maybe sand clear coat?
Any hints or tips? Thank you!
da prez
Wilmot Wi
Re: Painting my plastic wind deflectors?
April 30, 2018, 03:05:20 PM »
They may have a coating like the windshield. Pick at a spot and see if the film lifts. You could sand , prime and try again.
da prez
pocket aces
Tampa, Fl
May 01, 2018, 05:54:00 AM »
During the prep process I did scuff them up. They did not seem to have a coating on them. The paint adhered good to the plastic. Just want a smooth glossing finish. Not sure of the finishing sanding technique. I am using rattle can paint.
May 01, 2018, 08:21:57 AM »
This guy in St Augustine will make you a set of new ones.
https://bikescreen.com
He's very reasonable and does good work.
He has several colors to choose from as well.
Steel cowboy
Spring Hill, Fl.
May 01, 2018, 06:16:11 PM »
Should have painted the back side of them only, this way you can't scratch the paint from the front side and wipe away the bug juice much easier. Just saying.
2001 black interstate
2003 Jupiter Orange wing
shortleg
maryland
May 01, 2018, 06:56:52 PM »
If you really want it more like glass.
Clear them with a good 2k clear and sand with 1500
and then buff with a good quality rubbing compound.
I have gotten great results doing it this way.
Hooter
S.W. Michigan
Reply #6 on:
May 01, 2018, 07:21:55 PM »
I used regular Rit Dye. Cleaned the lexan really well with warm soap and water. Rinse well. Made a strong solution of the dye in hot water. Used a container big enough to submerse the lexan being colored.
Left them in the solution all night, rinsed the next morning. I think I did mine twice in order to get a noticeable result.
