February 14, 2026, 05:01:13 AM *
Author Topic: Changing the center cover  (Read 1263 times)
NighthawkVTX
Gainesville, Fl
« on: April 30, 2018, 04:29:38 PM »
I have a center cover with the right side tab insert broke to therightside cover will not lock in place,
I've found a couple parts on e bay, but I was wondering if anyone has a "trick" to get it to lock in  place. Currently it's taped down.
If I do replace it how do I get the key hole to come out, and are there any surprises I should know about?
If at first you don't succeed, then perhaps skydiving isn't for you
« Reply #1 on: April 30, 2018, 04:42:44 PM »
Done a couple.  Pretty easy.  You will see as you go obvious. Just don't put the tip sensor back on upside down.
« Reply #2 on: April 30, 2018, 05:06:26 PM »
I took my center cover off. I hated doing it, it was awful. And I put
the tip-over sensor on upside-down, so I had to do it twice. There's
a prominent arrow on the tip-over sensor to help you put it back on
right you might want to look for.
« Reply #3 on: April 30, 2018, 05:50:40 PM »
The only part of removing that thing is not obvious is the grommet at the bottom.  Once you remove the side bolts you just pull up and it pops out of that center lower grommet
« Last Edit: May 01, 2018, 03:43:53 PM by Chrisj CMA » Logged
« Reply #4 on: May 01, 2018, 01:27:10 PM »
If you were asking how to make the side cover stick many have employed velcro after that mistake.  Some have installed a small mostly unnoticeable screw.
rafster
Gastonia, NC
« Reply #5 on: May 01, 2018, 06:46:56 PM »
If you're referring to the lock tumbler assembly thingy, it's easily removed once you have the other center cover bolt removed and the left side cover removed. Next move the cover toward the front of the bike to get hour hand in there. There is a "U" shaped clip holding the lock assembly in place which can be accessed from the left side.  You may need to rotate the clip so that the open end faces right and the closed end faces left. This gives a straight line pull direction to the left side. Removing the clip itself was straightforward, but I seem to recall  it required more effort than I expected.
da prez
Wilmot Wi
« Reply #6 on: May 02, 2018, 01:31:17 PM »
  I tried the grommet method. So far , so good. A side cover grommet worked (yes , worked) in where the tab was will work. It takes a little doing , and the center cover need not be removed. I am referring to the elongated one.
                                     da prez
« Reply #7 on: May 02, 2018, 04:08:58 PM »
                                     da prez
+1 I've had one side like that for 4 years and 50k. No problems. New grommets in the side cover is recommended. Don't want it worn and loose.
