February 14, 2026, 06:51:18 AM *
Author Topic: Adding a sound system  (Read 1502 times)
greggh
OMAHA NE
« on: May 02, 2018, 07:47:03 AM »
1998 Standard dressed as a Tour Model with OEM hard bags.
Adding a Boss Audio MC500 Sound system to my ride.
What is the easiest way to install?
Is there a Wire I can run to too have it turn key or do I need to run hot and power system down all the time?
What installation tricks are there?
I am certainly a wiring challenged individual and don’t want to cause any issues.
Any and all input would be greatly appreciated.
TIA
Greggh
« Reply #1 on: May 02, 2018, 12:42:34 PM »
Get a pc-8 or some fashion there of and it will only be triggered with the key.
https://www.easternbeaver.com/Main/Wiring_Kits/Fuseboxes/PC-8/pc-8.html
Jruby38
Oxford Mass.
« Reply #2 on: May 02, 2018, 01:08:33 PM »
I installed the Cycle Tune Kit on my standard and ran power to a toggle switch so I can have tunes without the key on.
greggh
OMAHA NE
« Reply #3 on: May 02, 2018, 01:13:25 PM »
I see what you are getting at, but that is a bit more Technological than my comprehension of electronics.
Thank you tho.
« Reply #4 on: May 02, 2018, 02:27:15 PM »
Who me? Or Jruby?.
greggh
OMAHA NE
« Reply #5 on: May 02, 2018, 06:16:23 PM »
My apologies
That looks nice but beyond my knowledge
« Reply #6 on: May 02, 2018, 06:49:42 PM »
My apologies
If so, use the Acc. wire as a trigger for a relay.
greggh
OMAHA NE
« Reply #7 on: May 03, 2018, 03:04:22 AM »
My apologies
Meathead.  How does one locate this ACC wire?
« Reply #8 on: May 03, 2018, 04:24:43 AM »
My apologies
It's in the right side cover. There have been pics of it before. I will try to find them later. Got to get ready for work now.  cooldude
Jims99
Ormond Beach Fl.
« Reply #9 on: May 03, 2018, 04:57:56 AM »
I also put mine on a separate switch so I can listen anytime. I also put a usb charger for phone on the same switch. ( it has an indicator light on it so I don’t leave it on)
99 tourer
00 interstate
97 standard
91 wing
78 trail 70
greggh
OMAHA NE
« Reply #10 on: May 03, 2018, 05:10:28 AM »
I have thought to using a switch for that purpose.
Just being cautious about the wiring anything up.
Mechanics I can handle, wiring is not my strong point.
I have and have seen a lot of friends wiring and they resemble a rats nest.
« Reply #11 on: May 03, 2018, 10:56:18 AM »
It doesnt get any simpler than to wire a pc-8 it even comes with pictures. Two cables to the battery then to the fuse block then inset hot wire and ground wires and you are done. It gives you multiple fuses to wire in more things. Dont be askeered.
« Reply #12 on: May 03, 2018, 11:44:32 AM »
I used a pc-8.  Added a selector sw so I can run it with engine off.  If I do that I plug in a 6 amp charger if it's going to run awhile.  Set up the audio so it can play from the phone (Pandora etc), gps mp3's, or satellite. Has bluetooth, a preamp mixer with crossover, 300w amp. Comes in handy at group rides, at the motel when we're having drinks.
« Reply #13 on: May 03, 2018, 04:50:01 PM »
My apologies
I'm sorry, I couldn't find the pic of it on here. If my memory serves me correctly. It is 2 empty female bullet plugs inside a clear (yellowed by age) boot. It is up in the top right section under the right panel. When you locate the boot with the 2 wires in it, measure voltage. There will be nothing with the key off and 12 volts with it on. I hope this helps. Maybe someone better at searching can find the pic.  cooldude
greggh
OMAHA NE
« Reply #14 on: May 03, 2018, 05:17:04 PM »
Than you meathead,
I believe I have seen that lead in the past.
I will check it out, hoping this weekend.
Thanks to all for advice and input!!
Galex
2003 Honda Valkyrie F6C Standard aka: Lola
Usa
« Reply #15 on: May 10, 2018, 04:34:47 PM »
went with a:
BOSS Audio MC900B 500 Watt, 4 Channel, All-Terrain, Weather Resistant Amplifier System With Bluetooth Multifunction Remote
it automatically comes on with ignition and auto pairs up with my phone via bluetooth...
greggh
OMAHA NE
« Reply #16 on: May 11, 2018, 05:09:00 AM »
went with a:
What wires did you connect to for use of ignition?
I Have looked and don't see an obvious set of female connections.
Galex
Usa
« Reply #17 on: May 11, 2018, 02:42:10 PM »
on the right (key) side behind the side cover you will find the ignition wire that directly connects to its dedicated fuse.  apologies as I type this response I don't remember the color. i simply spliced into it.  the amp fit perfectly under my seat.  to do things right i recommend removing the items in the way and lifting the tank s few inches.  took me about 3 hrs all in...
« Reply #18 on: May 13, 2018, 02:17:29 PM »
I have added a relay for some external stuff (audio, gps, radar detector) and its powered from a connector on the right side of the bike under the cover.  Here is a link to the picture.
Pardon the black lines but I am still learning how to edit my pics
https://www.dropbox.com/s/w79kn7zwqjspp92/IMG_0349.JPG?dl=0
