February 14, 2026, 06:51:15 AM *
Author Topic: 2003 valkyrie Gas leak  (Read 1133 times)
Formornow
« on: May 02, 2018, 01:15:34 PM »
I took my gas tank off to have it painted and I removed the petcock and the fuel level sending unit. After it was painted, I put the items back on. There was no gasket on the sending unit and I thought this was odd. I have searched for a gasket for it and can not find one. Anyway, needless to say, i have a gas leak. Any suggestions on where to get a gasket or what I can use to stop the leak?
Thanks a bunch!!!
Avanti
Stoughton, Wisconsin
« Reply #1 on: May 02, 2018, 01:21:09 PM »
Check this part number 6 (O-RING 16958-KM9-005) (14.2x1.3)
http://shop.westernhonda.com/fiche_section_detail.asp?section=428395&category=Motorcycles&make=Honda&year=1999&fveh=13073
« Last Edit: May 02, 2018, 01:30:34 PM by Avanti » Logged
longrider
Vernon, B.C. Canada
« Reply #2 on: May 02, 2018, 03:43:50 PM »
If it is the gasket (o-ring) for the fuel sender it is #26   O-RING (39.5X5)
91305-MC7-000
« Reply #3 on: May 02, 2018, 03:49:23 PM »
2003 Valkyrie...  fuel level sending unit.
2003 Valkyries were all Standards... only Interstates have gas gauges... maybe I don't
understand...
« Reply #4 on: May 02, 2018, 04:00:26 PM »
understand...
yeah, it doesn't add up. Maybe somebody put an Interstate tank on it ?
Avanti
« Reply #5 on: May 02, 2018, 05:52:38 PM »
91305-MC7-000
This would be correct for the sending unite. I guess some pictures or some type of clarification would be in order.
Formornow
« Reply #6 on: May 03, 2018, 06:14:32 AM »
Not sure what is up, but the unit has a some wires that come out and go towards the handlebars, but my bike has no gas gauge or gas light. These wires were not hooked to anything when I removed the tank.
« Reply #7 on: May 03, 2018, 06:32:54 AM »
Interstate tank:
Standard/Tourer tank:
« Reply #8 on: May 03, 2018, 06:48:40 AM »
Sounds like a previous owner put an I/S tank on . You’ve almost a couple extra gallons now. There is some workaround for hooking up a gauge.
« Reply #9 on: May 03, 2018, 07:46:38 AM »
... and a plate somewhere (RedEye?) that you can use to close off the sending unit hole and
forget about it.
« Reply #10 on: May 03, 2018, 02:30:05 PM »
forget about it.
BigBF makes the blockoff plate for IS tanks. www.bigbf.com
