February 14, 2026, 06:52:15 AM
Did I jinx my Alternator...
Topic: Did I jinx my Alternator... (Read 940 times)
mrgeoff
My 99 CT..."Liahona"
Augusta, GA.
May 03, 2018, 05:41:10 PM »
Well, I thought I was done but I have a slight problem with my alternator...I just took it out and cleaned it up, the brushes looked good still and the rubber dampers look good too, so I just cleaned it up and put it back together...I went for a 100 mile ride today and I notice a "whirling sound" coming from the alternator...did I clean it too well...??? I'm hoping it might be the rubber dampers...the bearings were good as I checked them while apart...Did I mess up the dampers...??? sounds like the noise is coming from the front of the alternator...!!
Let me know your thoughts...I do have the new rubber dampers and new brushes that I can install if you think I should...!!!
Last Edit: May 03, 2018, 05:43:13 PM by mrgeoff
mrgeoff/SANDMAN
Re: Did I jinx my Alternator...
May 03, 2018, 05:47:07 PM »
I don't think so. There is not really anything that you could have got wrong with the dampeners. Maybe you are just listening to it more intently since cleaning it.
May 03, 2018, 05:59:20 PM »
Some alt whine. Some don't. Puttin out the right voltage should be good to go. RIDE SAFE.
mrgeoff
Augusta, GA.
May 03, 2018, 06:10:59 PM »
It is putting out good voltage...Think I just need to get it dirty again...Now that sounds crazy doesn't it...!!! just have to get use to the clicking/ whirling sound I guess...!!!
Last Edit: May 03, 2018, 06:12:44 PM by mrgeoff
mrgeoff/SANDMAN
