February 14, 2026, 06:52:15 AM *
Author Topic: Radiator and cooling system question  (Read 1551 times)
Motodad71
Westerville OH
« on: May 06, 2018, 12:38:19 PM »
Took my wife for first time on my new to me old fat lady, runs like a top and my wifey really enjoyed the quick loop around the lake. Today is one of the warmer days had so far, and I got to hear/see my radiator fan finally kick on while stopped briefly talking to a friend of mine walking on the neighborhood sidewalk. When I got home I smelled coolant a bit, and to my surprise I saw what looked to be a small boil over and some residual coolant spots/streaks along the right side of bike. Does this sound to y'all like too much coolant in the system, or perhaps air in the system or potentially BOTH? If air in the system what is the best way to burp it out? I apologize in advance if this is a redundant question or issue.  Lips Sealed
BB
« Last Edit: May 06, 2018, 12:40:56 PM by Motodad71 » Logged
1997 yellow/black Valkyrie standard "Thor"
« Reply #1 on: May 06, 2018, 02:35:42 PM »
Check the overflow reservoir, it’s marked for hot level and cold level.
If you are concerned about air in the system for some reason just run it with the radiator cap off and blip the throttle. Air will burp out if it needs to.
Sounds like just a loose hose fitting. Check the one at the thermostat
« Reply #2 on: May 06, 2018, 02:40:13 PM »
Expansion tank is under/behind left side cover-kickstand side. Check the radiator hose clamps-common problem. Only other thing-well 2 things-loose radiator cap or-sigh-water pump.  Lips Sealed Check the easy stuff first. Far as the fan coming on-long traffic lights when hot out and slow parade running WILL bring the fan on if everything else is correct. RIDE SAFE.
Motodad71
Westerville OH
« Reply #3 on: May 06, 2018, 02:58:35 PM »
Thanks for advice, the reservoir was at the low level, and the hose clamp is good and tight. It does appear to be coming from the cap, I’ll burp the system once everything is all cooled down.
« Reply #4 on: May 06, 2018, 04:09:52 PM »
Sounds to me like the cap is not sealing properly.
F6Dave
Cap
« Reply #5 on: May 06, 2018, 08:06:15 PM »
Sounds like the radiator cap to me as well. I had it leak on one of my Valks. I put the cap on a bench and tapped the tangs very lightly to tighten the seal. Hasn't leaked in years after that.
Tfrank59
'98 Tourer
Western Washington
« Reply #6 on: May 06, 2018, 09:09:49 PM »
 if it's not the cap leaking it could be the hose clamp way inside at the thermostat which needs to be tightened up. I was able to do mine using quarter inch drive extensions and one universal joint (it's a 6 mm hex).
-Tom
« Reply #7 on: May 06, 2018, 09:13:02 PM »
same issue leaky radiator cap tried bending tabs of cap downward so fits tighter, helped but still not 100% leakproof, so went to Autozone and got a 1994 honda accord radiator cap for 10 bucks since Honda dealers wants 30 bucks for honda valkyrie OEM cap.   But,  now have a slow fin leak top left inside corner of radiator not in front but in back of radiator.  sure beats antifreeze spewing out the radiator cap though all over the gas tank and chrome.
« Reply #8 on: May 07, 2018, 06:20:28 AM »
Go to Evans waterless permanent coolant - it runs w/o pressure with it's very high boiling point.  I run it in all my bikes.  No more cooling system maintenance.  Check out Jay Leno's video on it. https://www.youtube.com/watch?v=t7PykrgzWPQ
« Reply #9 on: May 07, 2018, 06:52:57 AM »
I've had evans in mine since '01, zero problems.  cooldude
Motodad71
Westerville OH
« Reply #10 on: May 07, 2018, 09:58:15 AM »
Interesting, I am intrigued but not crazy about also purchasing the prep fluid before going with the waterless coolant.
Motodad71
Westerville OH
« Reply #11 on: May 07, 2018, 09:59:26 AM »
It appears to be the cap area, I am not seeing any evidence of coolant migrating from anywhere else. I did burp the system yesterday, I shall see what happens soon.  Smiley
Wayn-O
Orem, UT
« Reply #12 on: May 08, 2018, 11:00:27 AM »
On the cap, try bending the two brackets that hold the cap on tight.  Bend just slightly inward so that it fits more snug when it's screwed on.  Make sense?
2000 GL1500C Valkyrie
2003 VT1100C Shadow Spirit
1998 VT1100C Shadow Spirit
1983 VF750C V45 Magna
Motodad71
Westerville OH
« Reply #13 on: May 08, 2018, 02:37:02 PM »
Yup but the tabs appear very tight, and the cap is a beeyatch to get on and off......tight.
« Reply #14 on: May 08, 2018, 03:16:19 PM »
           There is a set screw in a stock radiator cap. Needs backed off BEFORE attempting to take off radiator cap. Go on ahead and ask me how I know dat!  Roll Eyes RIDE SAFE.
Paladin528
« Reply #15 on: May 09, 2018, 10:19:54 AM »
the small hose that comes off the neck of the filler is the overflow running to the reservoir.  it can crack or split near the connection and start leaking when the bike is hot.  This should be repaired if it is the issue as it will result in fluid loss over time.
Motodad71
Westerville OH
« Reply #16 on: May 09, 2018, 02:15:23 PM »
I'll give that a good once over, but rode today in hot stop and go traffic with ZERO leaks of any kind.......looks to have been air in the system so far.
