February 14, 2026, 06:52:18 AM *
Author Topic: Battery Bolt Size  (Read 1732 times)
« on: May 10, 2018, 02:06:36 PM »
I hate to ask this simple question but I have searched the forum and the web and can't find the size of the bolt that connects the battery terminals to the battery.
I seemed to have mis-laid the one I just pulled off.
Thanks.
« Reply #1 on: May 10, 2018, 02:11:17 PM »
Take the one you do have to hardware store and size it? I dont know the answer you seek.
« Reply #2 on: May 10, 2018, 02:14:39 PM »
Yeah that is my back up plan.
« Reply #3 on: May 10, 2018, 02:20:51 PM »
Back up plan.  crazy2
You could have been home from the hardware store and had some riding accomplished already
« Reply #4 on: May 10, 2018, 02:50:09 PM »
Well lets see, maybe, the store I would need to go to is about 7 miles away.  About 45 minutes total.  Since I am going there tomorrow anyway.....
Since I already lost one ,and thats the one I need to replace and if I take the other one, then if I lose that one.....
Tell you what when I find out I will post it here so if someone else searches the will find the answer.
« Reply #5 on: May 10, 2018, 04:07:08 PM »
Any nut and bolt that fits will work as a temp.
« Reply #6 on: May 10, 2018, 04:11:05 PM »
What Hook said  cooldude You might have to cut or grind down something you have on hand.
Jruby38
Oxford Mass.
« Reply #7 on: May 11, 2018, 12:32:14 PM »
10 MM
« Reply #8 on: May 11, 2018, 01:35:43 PM »
10 MM
Wrench size?  Thread diameter (obviously not)?  Shaft length?
I'm gonna guess M6x1.00 x 12mm LG, requiring a 10mm wrench/socket.
« Reply #9 on: May 11, 2018, 02:56:21 PM »
Yep that's it.  Found and installed.  Now have four spares.
ridingron
Orlando
« Reply #10 on: May 12, 2018, 08:30:00 AM »
Which one, 10mm or 6mm?
« Reply #11 on: May 12, 2018, 09:02:53 AM »
It’s the one GR sited. 10mm wrench size.
« Reply #12 on: May 12, 2018, 09:08:43 AM »
You guys crack me up.  All this over a bolt.  A five second Google search, and the answer
https://www.summitracing.com/parts/ysa-5bnbss22m?seid=srese1&cm_mmc=pla-google-_-shopping-_-srese1-_-yuasa-batteries&gclid=EAIaIQobChMI-O384s2A2wIVj4bACh2EugiKEAQYASABEgJ4E_D_BwE
And yes these will take a 10mm socket even though its a 6mm bolt.   uglystupid2
« Last Edit: May 12, 2018, 09:20:38 AM by Chrisj CMA » Logged
« Reply #13 on: May 12, 2018, 09:11:54 AM »
Grin WTH you can’t possibly expect car bolts to fit on a motorcycle ?
« Reply #14 on: May 12, 2018, 09:19:09 AM »
Im always telling people these are really car engines in a motorcycle so ya, why not? crazy2 2funny
« Last Edit: May 12, 2018, 09:22:46 AM by Chrisj CMA » Logged
« Reply #15 on: May 12, 2018, 09:22:41 AM »
Why not ? Clearly the only chance of those bolts working would be if you were using “car oil” and “car tires”. Then it’s still a 50/50 proposition.  Smiley
« Reply #16 on: May 12, 2018, 09:25:23 AM »
50/50 well then one should fit and he has the other one already so looks like a win  Evil
« Reply #17 on: May 12, 2018, 09:31:48 AM »
 2funny cooldude
« Reply #18 on: May 12, 2018, 10:12:05 AM »
Once you have your (correct) bolt, a very nice trick for taping it into the captured nut in the battery post is to shove a small piece of sponge or foam under the captured nut to raise it up, so the bolt easily taps into the nut threads.
I don't have a nice fuse block setup like most do (and can't be trusted with auto electric enough to put one in myself) and have a number of wires run to my positive terminals, and the ordinary battery bolt will not go down far enough to tap that captured nut.  Drove me crazy fiddling with it, until i learned to stuff in a small flexible non conductive spacer under the captured nut.
« Last Edit: May 12, 2018, 10:14:50 AM by Jess from VA » Logged
« Reply #19 on: May 12, 2018, 03:31:54 PM »
Jess, I'm definitely no electrical expert. But I'm sure if you wanted it done,we could do a fuse block in Roanoke. Or at least go thru the specifics of it.
« Reply #20 on: May 12, 2018, 03:45:46 PM »
Thanks Rob, but I'd rather be riding or BSing, and/or drinking beer.  My octopus may be red neck, but it's never failed either.
In another year or two, Big Bill will be through again, and if I don't give him some work I feel like I'm slacking.   Smiley
« Last Edit: May 12, 2018, 03:47:42 PM by Jess from VA » Logged
« Reply #21 on: May 12, 2018, 03:48:45 PM »
« Reply #22 on: May 14, 2018, 06:57:31 AM »
Except what you came up with is a 22mm long bolt, probably too long unless someone has a whole mess of ring terminals on each battery terminal.
« Reply #23 on: May 14, 2018, 10:47:22 AM »
Lol. I wouldn't know how long a bolt he would need. But he has the other one. It says in the page I posted that the kits are available in several lengths. A phone call may be required as I didn't see a drop-down menu to change kits.
Or a hacksaw and file and you can make any length you need as long as it's shorter than 22mm lol again
Still cracking me up. This isint rocket science
Off the same site if one preferes normal length
https://www.summitracing.com/parts/bkm-15-1728
« Last Edit: May 14, 2018, 10:59:46 AM by Chrisj CMA » Logged
« Reply #24 on: May 14, 2018, 12:28:47 PM »
No, not rocket science.  I suppose I'm a little over-zealous with the details.  In my job, getting the small and simple details wrong or something mis-ordered means extra re-work or extra cost getting the right items rushed in, sometimes causing missed deadlines.
« Reply #25 on: May 14, 2018, 04:39:05 PM »
Ok, I asked the original question because I really did not want to remove the other bolt (the positive one) on the off chance I'd lose a wire.
I have a real rat's nest of wires in there because I just kept adding stuff.
And yes I was being lazy.
but what a great conversation we have had.   Grin
« Reply #26 on: May 14, 2018, 04:51:37 PM »
Yes great conversation. Nice cooldude
