February 14, 2026, 06:52:13 AM *
Author Topic: help with splitting carbs  (Read 1103 times)
GreenValk
NoVa
« on: May 11, 2018, 10:11:28 AM »
Hello experts,
I am repairing a fuel leak in the o-rings of the fuel rail. Pulled the carbs. Split one side, no problem, and have it back together. But now I am having trouble splitting the carbs on the other side.
Any recommendations on how to get them apart.
Thanks in advance, Steve
da prez
Wilmot Wi
« Reply #1 on: May 12, 2018, 06:16:59 PM »
  Not there , so just going thru the motions. Are the joint bolts removed. A shot of wd40 may help.
 Use a blunt soft punch to the most solid part of the carb. Tap and move. Lube and repeat. Do not get in a hurry. Kind of hard to explain in writing.
                                                   da prez
bill-jr
VRCC # 35094
murfreesboro
« Reply #2 on: May 13, 2018, 06:20:26 AM »
The redeye kit sends a little piece that goes between the carbs to pey them loose maybe google the kit ?
If i remember it was plastic ?
99' Black tourer
GreenValk
NoVa
« Reply #3 on: May 13, 2018, 06:54:14 PM »
Thanks for your assistance. I did get them apart with a lot of soft taps on a flat blade screwdriver. The screw driver was placed against the carbs at the joint held together by the bolts and dowels. The is a little exposed ridge on one joint and a ridge with identification numbers on the other. It took two people, one holding the cards and one tapping, alternating between the joints. Long slow process. But it is all back together now. Running strong and no gas leaks. cooldude
97BLKVALK
VRCC#26021
Detroit Lakes, MN
« Reply #4 on: May 14, 2018, 06:55:41 AM »
Great Job Green Valk!   cooldude
1997 GL1500C - Black
1997 GL1500C - Purple
1997 GL1500C - Bumble Bee
1998 GL1500C - Blue and Cream
