February 14, 2026, 06:52:17 AM *
Author Topic: Epoxy tips for replacing brass screw holder  (Read 1182 times)
NighthawkVTX
Gainesville, Fl
« on: May 13, 2018, 10:24:40 AM »
I recently removed my speaker housing to access the inside of my fairing. Needless to say, I stripped out several of the brass parts that the screws go into. I purchased replacement brass, but would appreciate any tips or suggestions on securing the brass back in place.
If at first you don't succeed, then perhaps skydiving isn't for you
NewValker
VRCC# 36356
Oxford, MA
« Reply #1 on: May 13, 2018, 10:35:25 AM »
JB Weld. DON’T get any in the threads!
Craig
Turns out not what or where,
NighthawkVTX
Gainesville, Fl
« Reply #2 on: May 13, 2018, 11:01:15 AM »
Thanks, sounds easier said than done
bikerboy1951
Grand Forks, ND
« Reply #3 on: May 13, 2018, 02:47:06 PM »
If you look at the back of the part the screw goes into you will see that there is a round disc in the middle.  Push or tap it back toward the front of the insert.  Put a dab of JB Weld into the hole where the insert was and push the insert back into place.  Take a small punch and tap the middle of the insert all the way to the back.  Run the screw in and out of the insert and wait for the JB Weld to cure.  You then have been able to reuse the old insert and it will not come back out again.
Brad
« Reply #4 on: May 13, 2018, 04:09:26 PM »
a little antiseize on the threads should stop it from bonding to the JB weld. Apply a small amount on the screw, thread it in, use that to get the insert to bottom out, and then remove. This is what I did on my broken bases in the fairing.
Dr K
Southern michigan
« Reply #5 on: May 13, 2018, 05:20:04 PM »
I used crazy glue
Sourdough
Tucson
« Reply #6 on: May 13, 2018, 08:02:54 PM »
Hey nighthawk,
I’m in Tucson also, wouldn’t mind seeing what you’re to your fairing. Figured I could learn something.
I pm’d you my cell/text.
Rick
01 I/S Black/Beige
97 Standard Bumblebee
« Reply #7 on: May 13, 2018, 08:21:34 PM »
I used crazy glue
+1
savy265
« Reply #8 on: May 14, 2018, 05:32:49 PM »
i  have  several  missing,where  do  i  buy  those  inserts tks
« Reply #9 on: May 14, 2018, 07:37:22 PM »
Scroll down on the left.
http://www.jkozloski.com/generic_parts.htm
Inserts for fairing, Honda part # 90316-MJ1-000
(not a bad idea to assume you may screw at least one of them up)
