February 14, 2026, 08:37:29 AM *
Author Topic: Tourer with IS ECU: Also add ECT Mod?  (Read 984 times)
Wilder
1999 Valkyrie Tourer
Wilmington, NC
« on: May 16, 2018, 05:24:41 PM »
I have a 99 Tourer, and am installing an Interstate ECU.  What do my esteemed colleagues think of adding the ECT Mod also?
And I hope to see you all at Inzane in Roanoke, VA.
Dave Wilder
Dave Wilder
Retired Military Chaplain
Certified Relationship Coach
Motorcycle Enthusiast for 50+ years
matt
Derry New Hampshire
« Reply #1 on: May 16, 2018, 05:46:49 PM »
I say do that and install is springs in carburetors
RDKLL
VRCC #1231 VRCCDS #271
Mesa, AZ
« Reply #2 on: May 16, 2018, 06:30:58 PM »
I did the carb springs and IS ECU or ICM on my bobber and the combination of those and the removal of a bunch of weight makes it pretty quick
Wilder
Wilmington, NC
« Reply #3 on: May 17, 2018, 06:52:57 AM »
Matt:  Just to be sure I understand: you suggest doing 3 separate things (1) Interstate ECU, (2) Interstate carb springs, and (3) the Engine Coolant Temperature Modification/aka ECT Mod?
I will order some of the IS carb springs right away, already have the IS ECU to swap out.  And I'm wondering if the ECT Mod is a good idea along with the IS ECU, or if they might fight against each other.
Dave Wilder
Dave Wilder
Wilder
Wilmington, NC
« Reply #4 on: May 17, 2018, 06:56:07 AM »
Rdkill,
Great looking Bobber!  I bet those pipes are seriously loud.
IS ECU/ICM plus springs makes sense.  Have you ever tried the ECT Mod?  That might be my next improvement.
- Dave
Dave Wilder
matt
Derry New Hampshire
« Reply #5 on: May 17, 2018, 03:46:32 PM »
They will work together,  you can put a switch in it so you can adjust advance. I believe someone had a plug and play set up for the ect. Using that you dont have to cut up wires. I have not used plug and play but have done a couple that I have soldered together. Search on site for plug and play I believe it had some good reviews
Matt
