March 31, 2026, 04:14:42 AM *
Author Topic: Me butt puckered momentarily.  (Read 801 times)
« on: May 20, 2018, 01:20:47 PM »
Headed for home being pushed by BMW dual sport who is catching me on the straights and falling back in the curves. If he was pushing me in the curves I would have waved him past. On the straights I'm doing about 10 over the posted speed. Don't need nor want another speeding award.
I didn't want him in front of me slowing me down in the curves.
I don't know if he knows the road so on the deceptive bends I give him the caution hand sign.
I stand up on the pegs for the first dip/bump otherwise it's a tooth jarrer. He of course boings across it with his 13 feet of suspension travel.
On we go and here comes another dip/bump.
Up on the pegs once more and OH BUGGER the right grip slide off the handlebar snapping the throttle closed.
So I'm up on my feet with a firm grip on the left bar and trying not to make any move that will deflect form the straight and narrow.
I do have a little right hand control because the wiring for the heated grip is till connected to the bike.
I drop the grip and slowly reseat myself. Of course twisting the bar does bugger all for throttle control .
I wave the bike behind by me. I'm in fifth so the engine braking isn't too bad. I'm also on a little down slope.
As I'm slowing I retrieve the grip and slide it back on the bar. Nope it wont control the throttle.
Now I can see the 2 pieces, the grip and the bar clamp aren't "meshing together".
I'm still slowing down.
OK so turn the grip back ad forth and yep everything meshes together.
Now all I have to do is keep a slight lateral pressure to the left so the meshing stays meshed.
Ha! Easier said than done. Too much pressure and I start to counter steer a little.
Not enough pressure and in a right bend the grip tends to slide down and out becoming unmeshed with the resultant snapping closed of the throttle.
Not what one wants when making a sharp right turn from a standstill at a junction.
Nor when moving off at a stoplight with vehicles close behind.  Shocked
Made it home and now my right shoulder feels like I've done 3 hours of Charles Atlas exercise.
« Last Edit: May 20, 2018, 01:23:44 PM by Britman » Logged
Thunderbolt
Worthington Springs FL.
« Reply #1 on: May 22, 2018, 04:41:22 AM »
I can see where that might cause some concern.  Roll Eyes
BobB
« Reply #2 on: May 22, 2018, 05:13:53 AM »
You should probably fix that.  I had Heat Demon heated grips on my Tourer that used whatever grips you wanted.  I had Kuryakan grips...
Savago
Brentwood - CA
« Reply #3 on: May 22, 2018, 12:09:18 PM »
Damn! That certainly can make you skip a heartbeat... but nicely done! A less experienced rider would panic and probably loose control.
msb
Agassiz, BC Canada
« Reply #4 on: May 22, 2018, 01:12:52 PM »
Had my throttle grip glue release in the heat during a ride in Morgantown WV at Inzane 2 years ago. Just cranked the throttle as I turned up a steep hill and the throttle grip came off in my hand. Somehow I managed to stay upright...I dropped the grip to grab onto the throttle tube just in time. Went back to pick up the grip and spent the next day monkeying around with grip glue trying to get it re-installed for my ride home the next day. I guess it was too hot and I didn't have enough time to let it set, so I wound up using a couple of strips of rolled up Gorilla tape on the tube and then forced the grip on. This got me going the next AM and actually lasted for the next 5 days until I got home.
Was definitely a "pucker" moment...something totaly unexpected .
'99 Red  & Black IS
