February 14, 2026, 08:51:52 AM *
Author Topic: Help Needed with Carbs after Two Brothers Exhaust Installation  (Read 1510 times)
thevalkdude
« on: May 22, 2018, 01:02:37 PM »
Hello Riders,
I just had to do it!! -  I found a set of Two Brothers six in to six headers for my 97 1500.
Install was fine however I am now running too lean.
What are my options - besides putting the stock pipes back on.
Thank you
« Reply #1 on: May 22, 2018, 01:21:17 PM »
If you are running a K&N air filter, try going back to stock and see how much that helps
thevalkdude
« Reply #2 on: May 22, 2018, 03:41:12 PM »
I believe I have a stock filter.
Thank you,
« Reply #3 on: May 22, 2018, 06:21:09 PM »
Did you see Sandy's suggestion over on the general board ? Are you sure you are running too lean ?
« Reply #4 on: May 22, 2018, 06:33:38 PM »
your not running lean. only the idle mixture screw for each carb needs to be opened to about 3 to 3 1/2 turns from lightly seated/closed. the screws are set lean from factory to meet epa testing.
turtle254
Livingston,Texas
« Reply #5 on: May 23, 2018, 06:56:49 AM »
Hello Riders,
Thank you
With his set up whats the average turns out on low speed jets (assuming 35 jet)?
thevalkdude
« Reply #6 on: May 26, 2018, 10:00:38 AM »
As far as running lean or not!
prior to installation of just one new tbr header - all was perfect.
After installing just one pipe - all still was perfect
Immediately after fire up after both pipes are on - it was sluggish at idle and rev. Good with 1/3 choke.
Good with no choke at 4k rpm - standing still.
Have not ridden yet.
I have come out 1/2 turn and test twice so am at 1 full turn from where they are from the start.
I did not screw them all the way in and then out. did not see the need since all was perfect before I started this whole thing.
I appreciate every thought.
turtle254
Livingston,Texas
« Reply #7 on: May 26, 2018, 10:22:50 AM »
You need to know where your at to fix the problem ... turn them all the way in and back out 2 3/4"turns to start. One maybe way off and ... out means turns them clockwise .. easy to screw up
and go the wrong way.
thevalkdude
« Reply #8 on: May 26, 2018, 11:26:37 AM »
Turns out I found out that I left one plug wire off.  Put in back on and I was pleased enough for a test ride.
Of coarse I had to idle it back down sine the wire was off on the last test.
Overall I have back it out 1 full turn from the setting it was at befor the install - when it was running perfect with stock pipes.
It pops here and there when I am at idle it is slowing down to almost a stop.  Does not seem to rap down as fast as it did.
Idle at 900 seems normal - the new normal!!
I appreciat all your input.
I am thinking possibly a half turn out might smooth the low end out and restore the idle down transition!!
Any thoughts.
all in all - I am dang happy to have a hot rod sounding bike for sure. Thank you again.
Forge
San Antonio, TX
« Reply #9 on: May 27, 2018, 08:37:06 AM »
This is James in San Antonio. Glad you’re digging the pipes! The hanging, slow to come down rpm is classic running too lean. The stock fuel screw setting is 1&3/4 turns from bottom. Assuming, that no one messed with the screws before you got the bike or that some have backed out, you can assume that you are now 2&3/4 out from bottom. There is no way to know for sure without bottoming them out first and checking each one. I would try another 1/2 turn, and then only 1/4 turn at a time after that if needed.
thevalkdude
« Reply #10 on: May 28, 2018, 01:01:33 PM »
Awesome advice. I believe I will do just that.
Thank you,
cc
