February 14, 2026, 08:51:51 AM *
Author Topic: trailer wiring  (Read 1279 times)
franco6
Houston, TX
« on: May 23, 2018, 02:34:59 PM »
 Found a nice bushtec roadstar ,got the wiring necessary from them ,hooked everything using the the wire connection from the regular 4 pin trailer harness that came already installed on the bike but then ,nothing .I would like to restart the wiring process but having a hard time locating a schematic that is readable. I know some have the bushtec harness , any tips? thanks
Fred
Enjoy the ride!
Avanti
Stoughton, Wisconsin
« Reply #1 on: May 23, 2018, 05:58:26 PM »
Check this out.
http://www.rattlebars.com/valkfaq/schematics/index.html
da prez
Wilmot Wi
« Reply #2 on: May 23, 2018, 06:39:41 PM »
  The bikes have European wiring. The trailer has American. A power converter is the easy way to go. There are several kinds . Some have the converter at the rear , some in the front part of the wiring.
  I have used both and did not have problems.  European wiring 5 wires , American 4 wires.
                                                da prez
« Reply #3 on: May 23, 2018, 09:24:52 PM »
I thought the Bushtecs have a 5 wire lighting system. It might be simpler than you think.
« Reply #4 on: May 24, 2018, 06:27:27 AM »
Another advantage of a trailer light converter is that they often take their power directly from the battery so that your trailer lights don't overload the vehicle's wiring.  This is not an issue if your small trailer's lights are LEDs.
franco6
Houston, TX
« Reply #5 on: May 24, 2018, 06:26:16 PM »
Thanks ,I was frustrated last night as the lights would not come on ,turns out the trailer p.o. had the wiring jumbled-up on the trailer, am still trying to get the brake lights to come on   Cheesy
Enjoy the ride!
Tim R
Sioux Falls, South Dakota
« Reply #6 on: May 27, 2018, 02:34:54 AM »
Here is what I used on mine when I started pulling a trailer behind the old girl. I wired it into the tongue of my trailer.
https://www.amazon.com/Hopkins-48845-Tail-Light-Converter/dp/B0002RNSPK
and this is the plug I used on the bike side, just did not use 1 of the wires all.
https://www.etrailer.com/Wiring/Hopkins/37995.html
« Last Edit: May 27, 2018, 02:37:38 AM by Tim R » Logged
franco6
Houston, TX
« Reply #7 on: May 28, 2018, 03:21:03 AM »
That s funny as I have the 6 square plug still in the bag unused . but after talking with the bustec people they convinced me to get their harness to match the trailer s plug {big price diff. Angry) But they were very helpful. the wiring in the trailer was shorting out ,so am in the process of sorting, rewiring,isolating all connections.Put new bearings on the wheels and waiting for the new tires to be delivered. maybe it will be ready for Inzane to carry spares and camping equipment. cooldude
Enjoy the ride!
franco6
Houston, TX
« Reply #8 on: June 05, 2018, 01:47:32 AM »
Up-date on the wiring, turns out Bushtec had a bad batch on isolators and harnesses and were very helpful in sending a new set and all is well! Good P.R. from them ,they were great  cooldude
Enjoy the ride!
