March 31, 2026, 05:55:36 AM *
Author Topic: Honda parts  (Read 804 times)
davit
Deerfield, WI
« on: May 27, 2018, 07:19:53 AM »
take forever to arrive from Partzilla.  I have some vacation time coming up in a week, and decided to postpone a trip and instead pull the carbs and replace some weak float springs and seeping fuel rail orings. However the last few times I've ordered through Partzilla it's been over a week for the parts to arrive, and I'm not giving them another chance.  Has anyone had luck with Western Honda, or can recommend a supplier who ships a timely manner?  Thanks.
Fuel rail leak kit and bowl gaskets will come from Redeye, never had a problem with him.
« Reply #1 on: May 27, 2018, 07:42:59 AM »
Western was slower than partzilla for me.
da prez
Wilmot Wi
« Reply #2 on: May 27, 2018, 08:25:38 AM »
Redeye  angel angel angel angel angel angel angel angel
                                      da prez
« Reply #3 on: May 27, 2018, 08:32:39 AM »
There was a thread from Leathel a while back where he replaced them with K&L’s (if I remember). They had slightly stronger springs I think. You might be able to get those on Amazon pretty quickly.
Ramie
2001 I/S St. Michael MN
« Reply #4 on: May 27, 2018, 09:41:37 AM »
I believe these are the float needles I used when I redid my Standard.
https://www.amazon.com/gp/product/B001KOD732/ref=oh_aui_detailpage_o04_s00?ie=UTF8&psc=1
davit
Deerfield, WI
« Reply #5 on: May 27, 2018, 09:53:02 AM »
Thanks!  I was just doing a search and this is the direction I'm being pointed.  Smiley
Forge
San Antonio, TX
« Reply #6 on: May 29, 2018, 06:36:32 PM »
I got those same exact ones from Amazon with Prime 2 day shipping.
MAD6Gun
New Haven IN
« Reply #7 on: May 30, 2018, 07:18:21 AM »
 I have a good relationship with my local Honda dealer. Ehlerding Motorsports. I find the part I need using a parts phish online and then go down to Ehlerding and talk to Brian in parts. He matches the prices I find. I have even borrowed tools from them to do repaired on Valkyries at home.
F6Dave
« Reply #8 on: May 30, 2018, 09:31:47 AM »
As I understand it when you order most OEM parts online, the seller has to get them from Honda first, which adds a few days to the process.  That's especially true for older bikes like the Valkyrie, where about the only parts any dealer might stock would be filters and brake pads.
I recently ordered OEM Valkyrie parts from Honda Direct Line and Competition Accessories.  In both cases everything arrived in about a week.
« Reply #9 on: May 30, 2018, 12:22:58 PM »
and why do u think the float springs are weak? what testing info do u have and use? never seen a honda spec on spring tension. do u have a spring tester? high heat and coil bind weakens springs. neither happen in the carb bowl.
https://www.rockymountainatvmc.com/ ships fast if they have the part in stock.   The only time partszilla was slow for me was when the part had to come from the main honda warehouse.
