February 14, 2026, 08:51:41 AM *
Author Topic: National Light Bar Wiring Question  (Read 1155 times)
Harv
One Bad Motor Scooter
Des Moines, Iowa
« on: May 31, 2018, 06:16:50 PM »
I just got my new National Cycle light bar. If I wire it per the instructions it will come on whenever I am using the high beams. For $45 + shipping I can buy a handle bar mounted off /on switch. My Cobra light bar has the switch right on the bar and I had it in the on position 99% of the time. I am a tight old bastard and don’t really want to buy it if I don’t have to . I like to run the driving lights all the time. Is that a bad thing? Is it possible to easily wire it that way and if so how? Thanks .
Harv Wink
Valkpilot
What does the data say?
Corinth, Texas
« Reply #1 on: May 31, 2018, 06:32:17 PM »
You can wire the lights using the diagrams in this post.  They will be on all the time (except when cranking the starter, when you don't want them on.)
http://www.valkyrieforum.com/bbs/index.php/topic,56705.msg546076.html#msg546076
VRCC #19757
IBA #44686
1998 Black Standard
2007 Goldwing
Attic Rat
VRCC # 1962
Tulsa, OK
« Reply #2 on: May 31, 2018, 07:49:42 PM »
Harv Pilot makes a kit with switch, wiring and relay that I have used for years that works really well Part # PL-harn3
https://www.amazon.com/Ailot-PLHARN3-Pre-assembled-Harness-Switch/dp/B001VGO800
Harv
Des Moines, Iowa
« Reply #3 on: June 06, 2018, 06:05:53 PM »
Thank you both for the info.
Harv Wink
