November 14, 2025, 04:30:25 PM *
Author Topic: spare battery wiring  (Read 1290 times)
« on: June 02, 2018, 07:49:20 PM »
I have a trailer for my motorcycle. I have a LiFe (no off gases) battery from my GW (reversed polarity) and a plastic ammo box I'll be using as a battery box. I want to charge the battery while driving, and use it to provide light for the inside of my trailer.
I will plug the battery to the bike when I plug in the wiring for the trailer.
Question is: How should I wire it in?
Straight positive and negative.
Just add a diode, so the trailer wont power the bike.
A relay, something along the idea of a deep cycle battery in a camper (not that I know that one either).
I don't see the battery charging from the bike as being a problem. It should take the power as long as it needs some.
It also gives me a spare battery in case of trouble (along with some long power leads to reverse the polarity).
Thank you for any advise.
« Last Edit: June 03, 2018, 08:36:48 AM by gordonv » Logged
WintrSol
Florissant, MO
« Reply #1 on: June 02, 2018, 08:04:52 PM »
You may have better/safer results with something like this: https://www.etrailer.com/Accessories-and-Parts/Tekonsha/2024-07.html
« Reply #2 on: June 03, 2018, 08:36:04 AM »
Thanks for the idea.
Looks like a 12V battery charger. For trailer batteries. I take it the trailer has a battery for electric brakes?
I just don't know if adding a non Lithium Iron battery charger is a good thing.
WintrSol
Florissant, MO
« Reply #3 on: June 03, 2018, 09:02:12 AM »
LiFe batteries are used as substitutes in motorcycles, and will charge OK with the bike's charging system, according to those that make and use them. You could look for a 12V-12V charger made for LiFe; never seen one, but I haven't searched, either. Using just a diode may not work, because the Voltage drop may preclude reaching full charge; maybe a Schottky diode would work?
My trailer uses a controller in the bike to activate the brakes, from the bike's power system; it uses a round connector, to get the needed contact count. I suppose you could put the driver in the trailer and power it from the battery in the trailer.
WintrSol
Florissant, MO
« Reply #4 on: June 03, 2018, 09:06:59 AM »
Article that may be useful: http://www.enerdrive.com.au/can-charge-lithium-battery-lead-acid-charger/
Beardo
Regina, Saskatchewan Canada
« Reply #5 on: June 03, 2018, 09:13:16 AM »
Solar panel mounted on top of the trailer?
http://www.canadiantire.ca/en/pdp/coleman-20w-12v-solar-panel-battery-charger-0112023p.html#srp
WintrSol
Florissant, MO
« Reply #6 on: June 03, 2018, 09:43:36 AM »
Out of curiosity, I looked further into this, and, while you can 'get away' with charging from the alternator, the best choice would be a 12VDC-120VAC inverter and a LiFe charger, or one used by RC modelers with a 12V input.
« Reply #7 on: June 03, 2018, 03:30:41 PM »
I have a 1W solar panel I would use on my car while parked during the summer while the MC was on the road.
I have a 75W cig power inverter.  I also have the LiFe charger. Would be fairly easy to add a cig outlet in the trailer, plug the inverter in with the LiFe charger plugged in and into the battery.
As for a diode, my thought was to stop power from going back into the mc battery. Since the LiFe battery should be close to full charge, it would just be a light load to maintain the battery. All lighting plugged into it would be LED. I have a white 5M strip for the inside lighting, and then was thinking of RGB for the underside of the trailer for light shows.
murraypeart (bandit)
Salmon Valley, BC
« Reply #8 on: June 15, 2018, 05:47:18 PM »
I can help you with wiring the battery when we are in Merritt this weekend. I need to know how you are connecting the trailer wiring between the bike and trailer before I can tell you what is required.
99 Yellow & Cream Standard,
- Valk windshield
- hard bags
- 6 to 6 pipes
- and other stuff
98 Burg and Cream Tourer
- Still rebuilding, but licenced and on the road
- Dual headlights
- Beetle Bags
- Custom Seat
- Custom Leather pouches replace side covers
« Reply #9 on: June 15, 2018, 07:01:19 PM »
I was thinking of the plug for a battery charger or some heated gear. Male/female plug. I thinking I might have a 6' extension. Then I could just add another plug to the battery in the trailer reversed polarity, then plug the extension in each plug so it would be positive-positive/negative-negative.
There's a Lordco and a Can Tire there, might be a nice little project.
