February 14, 2026, 08:52:36 AM *
Author Topic: rear wheel dampers  (Read 1130 times)
N0tac0p
« on: June 04, 2018, 06:50:58 AM »
anyone pick up and start making these?  or is it a dealer only part now?
Paladin528
« Reply #1 on: June 04, 2018, 07:01:30 AM »
There was a guy doing it once but they fell apart and are no longer available.  Dealer or supplier only.  Not that expensive.
« Reply #2 on: June 04, 2018, 07:04:28 PM »
I batch of bad ones, out of many. He actually passed. I have 2 sets from him. I bought a 2nd set just before he died, as they would no longer be available. How good are they, don't know,using a my 1st set now.
Should be available for Honda/online, but buy the one piece ones for an IS.
« Reply #3 on: June 04, 2018, 07:41:49 PM »
Two good sets in my bikes for years.  Better than rubber.
Paladin528
« Reply #4 on: June 05, 2018, 09:43:50 AM »
only the one piece ones are available now.  They are superceded for the old ones.
indybobm
Franklin, Indiana VRCC # 5258
« Reply #5 on: June 05, 2018, 12:28:33 PM »
One piece for the Interstate are better and less expensive.
So many roads, so little time
VRCC # 5258
Locomotive
99 Valkyrie: the Locomotive
Vermont, USA
« Reply #6 on: June 05, 2018, 07:14:08 PM »
Rich- redeye technical services, who offers a lot of the intake and fuel system parts and improvements for the Valkyrie, has mention on his page of an upcoming project to make them available in polyurethane, but needing some support finding someone with capacity to cast them (see mention on his Valkparts.com )
New (early '18) owner of a well kept '99 Valk Std in Yellow/Pearl. Other mechanized madnesses include a '14 Ural 2wd sidecar rig, an '81 Honda GL500 for my son to ride when out with me, a '51 Dodge M37, and a barn-full of other mechanical projects in the works
« Reply #7 on: June 05, 2018, 09:51:58 PM »
Polyurethane is what the other fellow (Shock Bushing Gary?) (now passed away) made his from, that I have had on two bikes for at least 5-6 years with great performance.
Some speculated that the dampers should really be of (Honda OE) softer rubber to cause less stress to the drive train, but I haven't had any indication of wear anywhere.
I have lost a Ujoint and a left rear wheel bearing, but both were before the dampers went in (no bad spline wear).  I don't have any rear end slop either, and I think the poly is better.  I had a Ford Taurus V6 that broke 3-4 motor mounts, until I went from OE rubber to poly motor mounts (and never broke another).
