November 12, 2025, 08:32:29 AM *
Author Topic: Waterpump Replacement  (Read 1826 times)
RonW
Newport Beach
« on: June 05, 2018, 10:46:54 PM »
I'm about to replace my water pump. Are there any precautions when doing this? Just double checking. I've read the instructions in the Oem manual.
2000 Valkyrie Tourer
« Reply #1 on: June 06, 2018, 01:25:49 AM »
Drain the engine oil.
RonW
Newport Beach
« Reply #2 on: June 06, 2018, 02:13:06 AM »
Darn, the manual didn't even mention that. good thing that I asked.
« Reply #3 on: June 06, 2018, 04:13:06 AM »
Go for a short ride so the engine is warm before you try to break them little bolts free.  Also give a few taps on head of each bolt with a hammer (I place the socket and extension on each bolt and tap on that)
Good luck
RonW
Newport Beach
« Reply #4 on: June 06, 2018, 04:55:04 AM »
will do.
Btw, there was a nationwide back order on Valk waterpumps but ended this month theoretically. Don't know when it began. I had to pay more from an Ebay vendor. $170 vs. oem websites $140. Didn't want that pump gone if the backorder lasted longer.
"..... Unfortunately, the manufacturer has contacted us in regards to this order, as this order contains one or more parts that are on a nationwide back order with the manufacturer. The part(s) that are back ordered are as follows with the estimated release date(s): 06/01/2018     19200-MZ0-000     WATER PUMP
« Last Edit: June 06, 2018, 05:08:47 AM by RonW » Logged
strawbobrob
It's all in the wrist.
« Reply #5 on: July 07, 2021, 08:48:40 PM »
If only I had. Following the manual just left my garage floor looking like the Exxon Valdez.  My faith in Honda just took a hit.
« Reply #6 on: July 08, 2021, 04:19:56 AM »
Yeah, well, don't beat yourself up.
I learned it the hard way also. Roll Eyes
RonW
Newport Beach
« Reply #7 on: July 08, 2021, 05:09:37 AM »
For the record, I was glad I posted this post in 2018. and inquired in advance. Whew. Who sez oil and water don't mix.
« Last Edit: July 08, 2021, 07:07:00 PM by RonW » Logged
« Reply #8 on: July 08, 2021, 05:25:22 AM »
Honda makes a service manual for each motorcycle
model they have. And they also have a "Common Service Manual".
I just went and looked in the Cooling System
section of the Valkyrie service manual. On page
6-4 where they're talking about how to
interpret hydrometer readings of your radiator
fluid: "Refer to th Cooling System section of the
Common Service Manual for coolant gravity specifications."
Anywho... they don't mention draining the oil in the
Valkyrie specific service manual, but in the Cooling
System section of the Common Service Manual it
sez: "
WATER PUMP REPLACEMENT
Drain the engine oil and coolent.
RonW
Newport Beach
« Reply #9 on: July 08, 2021, 05:43:27 AM »
duely noted.
Jruby38
Oxford Mass.
« Reply #10 on: July 08, 2021, 01:04:42 PM »
When I changed mine it cost me 50 cents for the C clamp on the top gooseneck to stop the leak. Make sure its tight.
