November 14, 2025, 05:38:03 PM *
Author Topic: Front Forks this Different Left to Right?  (Read 1134 times)
O-B-1
Vancouver, WA
« on: June 09, 2018, 07:14:58 PM »
Are the forks internally this different left to right?
https://photos.app.goo.gl/KLsBsbeQPBQmuBrB6
I am about to rebuild them and want to ensure I get the proper parts.
Any suggestions as to what parts should be replaced, beyond the fork seals?
Looks like I will be getting Progressive springs...
« Last Edit: June 09, 2018, 07:24:13 PM by O-B-1 » Logged
David W. Mitchell
1999 Honda Valkyrie GL1500C
« Reply #1 on: June 09, 2018, 07:43:44 PM »
yes.
do a search many posts on what to replace during a rebuild
O-B-1
Vancouver, WA
« Reply #2 on: June 09, 2018, 07:47:49 PM »
yes.
Yeap, will do... I searched the other day and most of them were just replacing the outer seals when they failed.
I will see if I can find a post where someone did the "Full-Monty" on the forks.
David W. Mitchell
« Reply #3 on: June 10, 2018, 02:07:32 AM »
Some photos i took a few years ago.
https://postimg.cc/gallery/36kismf6o/
Andy Cote
Windham, Maine
« Reply #4 on: June 10, 2018, 04:02:08 AM »
I usually do the bushings every time I do the seals.  Already there, not that much money and may help new seals last longer (at least that's what I tell myself).
Use Honda OEM parts.  Again, not that much money.
2015 Goldwing, basic black
Previously: 2000 Valkyrie Interstate, 1997 Valkyrie Standard, 1988 GL1500, GL1200 Standard, GL1200 Interstate and many other Hondas
« Reply #5 on: June 10, 2018, 05:18:53 AM »
I've rebuilt many forks in my garage. The best seals are made by "All Balls". They fit tighter and just fit better. There is a You Tube video on rebuilding VTX 1800 forks. They are the same internally, just a bit longer.
F6Dave
« Reply #6 on: June 10, 2018, 05:35:49 AM »
The left and right forks are very different.  One requires a special tool to disassemble.  It's been a while but I think one damps in one direction, and the other does the reverse.
« Reply #7 on: June 10, 2018, 05:42:10 AM »
u can make your own fork tool from electric heater element wrench $8 home depot
http://www.valkyrieforum.com/bbs/index.php/topic,70292.0.html
Ramie
2001 I/S St. Michael MN
« Reply #8 on: June 11, 2018, 07:38:09 AM »
The 1800 uses basically the same forks.
https://www.youtube.com/watch?v=TXZPzQqfAXc
