Rain Man
« on: June 17, 2018, 05:09:24 AM » |
Been experiencing a vibration from the rear of the bike and it only happens when riding upright in a straight line. If i lean to the left or right or even zig zag on the road it quits. Sometimes its more noticeable and sometimes it quits almost completely. I have new tires front and rear and i pulled the driveshaft and did all the required lubes and cleaned everything up. All looks great. Bike has just over 34,000 miles and has done this since i bought it at 27 thousand. I'm thinking maybe the dampers first or wheel bearings but I think that they would have failed by now and not come and go as its been doing. Any ideas on this?
JimmyG
« Reply #1 on: June 17, 2018, 05:15:34 AM » |
Don't ever ride upright, it causes vibrations
JimmyG
« Reply #2 on: June 17, 2018, 05:16:25 AM » |
Sorry dude, had to do it  Wheel bearing!! do the mod.
Rain Man
« Reply #3 on: June 17, 2018, 05:24:00 AM » |
Thank you. I will pull the rear wheel shortly.
« Reply #4 on: June 17, 2018, 06:44:23 PM » |
I doubt a wheel bearing would do this for 7k miles before failure. When I had a rear go from the first sign until race was seazed in the wheel less than 100 miles.
Rain Man
« Reply #5 on: June 17, 2018, 07:04:12 PM » |
thats what makes this all the more baffling. I'm gonna put it on the lift and see if i might can find looseness in swingarm or maybe even a engine mount. I'll find it I'm sure. This is my 11th or 12th bike and always did my own work. Being kinda new to the Valk brings new traits.
Ramie
« Reply #6 on: June 18, 2018, 06:31:59 AM » |
Check your tire pressures and for cupping. Might also check your shock bushings.
“I am not a courageous person by nature. I have simply discovered that, at certain key moments in this life, you must find courage in yourself, in order to move forward and live. It is like a muscle and it must be exercised, first a little, and then more and more. A deep breath and a leap.”
« Reply #7 on: June 18, 2018, 06:46:11 AM » |
This started with the new tires? Which models of tires?
jbrooks
« Reply #8 on: June 18, 2018, 08:14:39 AM » |
I would start with the shock bushings if they are the stock shocks.
« Reply #9 on: June 18, 2018, 09:56:05 AM » |
As the source of a vibration? Really?
« Reply #10 on: June 18, 2018, 12:27:54 PM » |
Actually, any vibration felt in the "rear end" unequivocally points to a problem with the universal joint. Say what you will, there is virtually nothing that can mimic the vibration caused by a failing universal joint.
rainman
Steve ( rainman) Eads
Bloomington Indiana
« Reply #11 on: June 18, 2018, 02:13:48 PM » |
have to checked the swing arm for tightness and bearings . never had that problem put sounds like you have cleared any problem's with drive train. out side of that the only thing left would be the wheel it self
« Reply #12 on: June 18, 2018, 03:24:55 PM » |
I bet this^^^^^^^ Even if it looks good it can be BAD!
da prez
« Reply #13 on: June 19, 2018, 06:57:58 AM » |
Pressure washing a bike can cause wheel bearing failure at an early age.
da prez
Gabriel
« Reply #14 on: June 22, 2018, 07:14:41 PM » |
I had this problem though I did not try the back and forth part. I would start to get a vibration at about 80/85 mph, it wasn't real bad but I wanted it gone so I pulled everything down (differential, shaft) and did not find any problems, everything looked great. I pulled the wheel weights and installed beads in the tire but the problem was still there. I pulled it down again and took a real close look at the u-joint and it did not seam to have any play in it, until I chucked it up in a vice. I secured one end in the vice and used a clasp wrench on the other and bingo you could see the play then but you could not see this while holding the u-joint in your hand, it was there you just could not see it. So I put a new one in it and that fixed the problem.  Shock bushings had no effect on my vibration, mine were shot and replacing them did nothing. BTW: I bought this bike and the problem came with it, just like yours...
« Reply #15 on: June 23, 2018, 08:57:22 AM » |
I had this problem though I did not try the back and forth part. I would start to get a vibration at about 80/85 mph, it wasn't real bad but I wanted it gone so I pulled everything down (differential, shaft) and did not find any problems, everything looked great. I pulled the wheel weights and installed beads in the tire but the problem was still there. I pulled it down again and took a real close look at the u-joint and it did not seam to have any play in it, until I chucked it up in a vice. I secured one end in the vice and used a clasp wrench on the other and bingo you could see the play then but you could not see this while holding the u-joint in your hand, it was there you just could not see it. So I put a new one in it and that fixed the problem.  Shock bushings had no effect on my vibration, mine were shot and replacing them did nothing. BTW: I bought this bike and the problem came with it, just like yours... Very helpful information.
