November 14, 2025, 11:17:55 AM *
Author Topic: LED FLASHER  (Read 1398 times)
bikerboy1951
Grand Forks, ND
« on: June 17, 2018, 05:38:01 PM »
I removed the flasher from my '01 standard and am looking to replace it with an led flasher.  The one I removed is a Mitsuba FR-3303.  Does anyone know of a direct replaced in led for this flasher.  I am having no luck finding one.
Brad
« Reply #1 on: June 17, 2018, 07:35:01 PM »
I have both bikes fully converted to LED.  These are the flashers I use.  They are two pin and plug directly into the three pin connector.  They have worked flawlessly for me.
https://www.ebay.com/itm/2-Pin-Electronic-LED-Flasher-Relay-FIX-Motorcycle-Turn-Signal-Bulbs-Hyper-Flash/192205224706?fits=Make%3AHonda&epid=1083435813&hash=item2cc052fb02:g:znwAAOSwrhBZMNnA
« Last Edit: June 17, 2018, 07:38:03 PM by Valkorado » Logged
DGS65
Time enjoy wasted is not wasted time
Nanuet, NY
« Reply #2 on: June 18, 2018, 05:06:34 AM »
If you change to LED do you still need Blinker fluid?  This is make it worth while Smiley
SCain
Rio Rancho, NM
« Reply #3 on: June 18, 2018, 08:41:14 AM »
The Show Chrome LED Flasher is a direct replacement.
Show Chrome LED Flasher Relay for Honda Cruisers - 13-306
Steve
D-Valk
« Reply #4 on: August 12, 2018, 01:14:29 PM »
I had to add diodes (from Super Bright) to prevent cross-blinking.
RonW
Newport Beach
« Reply #5 on: August 12, 2018, 01:40:02 PM »
If you replace both front & the rears with leds, you'd need an *metric diode kit* to reconfigure the idiot light wiring. Otherwise you'd get cross-feed (4-way flashing). If only the front but not the rears, or visa versa, you might not need an electronic flasher. As a temporary fix, just pull the idiot light bulb for the turn signal.
2000 Valkyrie Tourer
« Reply #6 on: August 13, 2018, 09:14:24 AM »
I had to have both a diode kit and a Led flasher installed on the Tourer to get everything working right.  It was not necessary on the Interstate, just a LED flasher.
RonW
Newport Beach
« Reply #7 on: August 13, 2018, 09:22:11 AM »
wasn't aware that the Interstates don't kneed the diodes.
Malkozaine
Lake County, Illinois
« Reply #8 on: August 13, 2018, 10:15:04 AM »
I know on mine I just replaced the Flasher with an LED on and replaced the lights with LEDs and that was it.  All was fine.  Though I get minor radio interference.
« Reply #9 on: August 13, 2018, 01:22:18 PM »
They have an indicator for each right and left.
