February 14, 2026, 10:25:06 AM
Front wheel bearing question
Topic: Front wheel bearing question (Read 1229 times)
Ken aka Oil Burner
Mendon, MA
June 23, 2018, 11:09:49 AM »
Took a ride last night, and noticed some feeling through the handlebars, like a rumble. I also noticed some ticking when the front brakes were applied. Jacked up the bike this morning, and the front wheel definitely rumbles when spun. I think it's time for bearings. I went to the Partzilla site. It looks like they only have 1 in stock, when looked up by the Honda number. They have another Honda part that's also a 6204UU, so I should be able to use that, right? If they're both a 6204UU, they both should have seals and be the exact same dimensionally. This is the one for the Valk:
https://www.partzilla.com/product/honda/91052-MZ2-A21
This is the other one:
https://www.partzilla.com/product/honda/96150-62040-10
Thanks for any thoughts.
https://www.amsoil.com/?zo=5889580
rockbobmel
Greenfield MA
Re: Front wheel bearing question
June 23, 2018, 11:25:39 AM »
I found this that popped up before.
http://www.jkozloski.com/generic_parts.htm
2002 Valkyrie GL1500CD
1996 Shadow 1100 ACE
Ken aka Oil Burner
Mendon, MA
June 23, 2018, 11:32:33 AM »
I saw that before from the Shoptalk link. It does pretty much clarify that a 6204 is a 6204. As for the last thought on the bearing section, I wish I could go to my local bearing house. Sadly, they've all dried up around here.
rugguy
2000 Valk I/S
Atlanta, GA
June 23, 2018, 03:56:27 PM »
Partzilla will automatically ship the newer replacement parts even if you order the older superseded part.
I hate sand....sand SUCKS!
I wear a helmet....."I'd rather have brains in my head than wind in my hair"
1999 Valk I/S
2000 Valk I/S
2001 BMW K1200 LTE (sold)
2002 FLHRSEI (for sale)
2006 FLHCTUI (sold)
June 23, 2018, 07:14:42 PM »
Find a local bearing house. The 6204 number will get you the right bearings and cheaper.
Ken aka Oil Burner
Mendon, MA
June 23, 2018, 09:15:13 PM »
Quote from: sandy on June 23, 2018, 07:14:42 PM
I wish there was one around here. The last one I knew of closed down a few years back, and an internet search came up dry.
Brian
Monroe, NC
Reply #6 on:
June 24, 2018, 03:12:03 AM »
Oil Burner, I suggest you buy two sets get the rear bearings too if you do not have a local bearing supply house. I change bearings at each 3rd new tire. Bearings are cheap insurance IMO. Some folks carry new bearings with them on long trips. I might suggest carrying a changed out set that feel fine verses tossing them? I know a guy here locally that throws in new bearings at each tire change. But then again he does his own work and we have a few good supply houses close by.
F6Dave
Auto Parts Store
Reply #7 on:
June 25, 2018, 06:47:09 AM »
I've bought 6204 bearings at both NAPA and Pep Boys. It's a very common bearing. Just make sure to get a 6204-2RS. The 2RS designates rubber seals on both sides.
