February 14, 2026, 10:25:31 AM *
Author Topic: Petcock Rebuild for 98 Standard  (Read 1202 times)
Kokomo Kevin
Kokomo, Indiana
« on: June 26, 2018, 06:14:51 PM »
Can anyone recommend Petcock rebuild kit for a 98 Standard? Would appreciate PN @ Company name, thanks!
Avanti
Stoughton, Wisconsin
« Reply #1 on: June 26, 2018, 07:16:50 PM »
Cover set K&L Supply Fuel Petpencil Repair Kit 18-5018  https://www.amazon.com/Supply-Fuel-Petpencil-Repair-18-5018/dp/B001KO4ZBU/ref=sr_1_fkmr2_1?ie=UTF8&qid=1487043123&sr=8-1-fkmr2&keywords=valkyrie+fuel+valve+kit
Daniel Meyer
I don't recommend the K&L kit...for the OEM petpencil go with the OEM cover set...16953-MBZ-B51   COVER SET, PETpencil - COVER SET, PETpencil      $33.01
Or a new valve, http://www.pingelonline.com/prodcat/fuel-valves.asp, this will lower your fuel reserve unless you modify the stand pipe.
Or this is what I did over 50,000 miles ago, put in an electric shut off run by a relay from the accessory power from the ignition switch, https://centuryfuelproducts.com/afc-111-12-volt-lockoff-multi-fuel-shut-off-valve (larger orifice if pulling a heavy load at high speeds) and used a filter https://www.amazon.com/Golan-Inc-Peak-Filter-60-312C-/dp/B00CAYC886?SubscriptionId=AKIAILSHYYTFIVPWUY6Q&tag=duckduckgo-ffnt-20&linkCode=xm2&camp=2025&creative=165953&creativeASIN=B00CAYC886 along with modifying the original shut off  http://www.valkyrieforum.com/bbs/index.php/topic,37577.0.html
« Last Edit: June 27, 2018, 09:23:20 AM by Avanti » Logged
Kokomo Kevin
Kokomo, Indiana
« Reply #2 on: June 27, 2018, 06:53:26 AM »
Daniel Meyer
The State of confusion.
« Reply #3 on: June 27, 2018, 07:59:30 AM »
I don't recommend the K&L kit...for the OEM petcock go with the OEM cover set...
16953-MBZ-B51   COVER SET, PETCOCK - COVER SET, PETCOCK      $33.01
CUAgain,
Daniel Meyer
Kokomo Kevin
Kokomo, Indiana
« Reply #4 on: June 27, 2018, 06:38:46 PM »
Kokomo Kevin
Kokomo, Indiana
« Reply #5 on: June 27, 2018, 06:43:51 PM »
Got one coming for $30 on Flea Bay, thanks
