February 14, 2026, 12:15:02 PM *
Author Topic: Cobra Light Bar Sw.  (Read 1568 times)
mrgeoff
My 99 CT..."Liahona"
Augusta, GA.
« on: June 27, 2018, 02:25:47 PM »
Thought I would ask those that might know...I have a 99 CT with one of the Cobra Light Bars with the 4 1/2 " flood lights on it...I am looking for the small plastic switch that came with it...I know it will be giving out soon, so I want to see if any one knows where I might be able to obtain one...Here in Augusta, Ga., Radio Shack has moved out...I hope some one can give me a replacement sw. location online so I can prepare for the day...I want to replace it with one that will fit in the same location on the light bar...Thanks for any help you can give me...!!!
mrgeoff/SANDMAN
« Reply #1 on: June 27, 2018, 02:59:15 PM »
Autozone sells an exact replacement. You can upgrade to a lighted model but you have to add a ground wire to make the light work. I get a red light so it doesn't dilate my eyes at night and I can instantly tell if the lights are on.
mrgeoff
Augusta, GA.
« Reply #2 on: June 27, 2018, 07:07:39 PM »
Thanks Sandy...I'll look into it...!!!
mrgeoff/SANDMAN
mrgeoff
Augusta, GA.
« Reply #3 on: June 28, 2018, 05:14:54 PM »
So far can't find a switch that will fit...it is a mini rocker switch SPST...smaller than I realized...!!!
mrgeoff/SANDMAN
Harryc
Sebastian, Fl
« Reply #4 on: June 29, 2018, 02:51:34 AM »
To me that little switch is kind of inconvenient. I'd put one of these on the handlebar and wire it into the light bar (or relay depending on your setup) and simply remove and bypas the switch on the light bar. Cap the hole or not. https://www.amazon.com/Single-Rocker-LED-Switches-SPST-Waterproof-12V-Motorcycle-Handlebar-3-1-0-swb1-smnt-Brn60-sbpn-3/dp/B0776L61XC
mrgeoff
Augusta, GA.
« Reply #5 on: July 04, 2018, 08:04:08 PM »
Well, I like to keep as much original stuff as I can on my 99CT( I do have a few Mods)...the switch that came with the Cobra Light Bar is a mini rocker switch...about 5/8 "W x 13/16"L...and that is the total W and L...the hole in the bar is about 1/2" x 3/4"...trying to find one that will fit...any help to where I can find a couple of them, would be great...!!!
mrgeoff/SANDMAN
« Reply #6 on: July 04, 2018, 08:25:37 PM »
Will these work ?
https://www.amazon.com/FBApayipa-Solder-Rocker-Switch-Toggle/dp/B01N2U8PK0/ref=sr_1_3?ie=UTF8&qid=1530763115&sr=8-3&keywords=Mini+rocker+switch#feature-bullets-btf
« Reply #7 on: July 04, 2018, 10:07:41 PM »
Thanks Rob; Those are the right ones.
