February 14, 2026, 12:16:19 PM *
Author Topic: Spark plugs  (Read 1429 times)
Funbaldguy
grand blanc Mi
« on: June 29, 2018, 05:39:52 PM »
Just wanted to ask what is working best? Most days consist of 90 miles round trip to work and back. Two to three miles on each end with about 40 on exspressways. Each way. Rearly anything shorter. It happens just not very often.
LB
2003
Upstate South Carolina
« Reply #1 on: June 29, 2018, 07:58:33 PM »
Stay with the stock plugs...they're cheap and work great. This motor does not need high end plugs.
Steel cowboy
Spring Hill, Fl.
« Reply #2 on: June 30, 2018, 04:31:51 AM »
Make sure you blow out the spark plug well, you don't want dirt or water going into the cylinder when you remove the plug, and use antisieze on the threads.
2001 black interstate
2003 Jupiter Orange wing
« Reply #3 on: June 30, 2018, 05:10:37 AM »
having great results with
https://www.championpowersports.eu/products/spark-plugs/power-sport/
low cost way to get the benefits of a reduced size center electrode.
Kokomo Kevin
Kokomo, Indiana
« Reply #4 on: June 30, 2018, 06:10:58 AM »
Has anybody tried the E diamond fire plugs? If so what # are you using?
« Reply #5 on: June 30, 2018, 06:22:08 AM »
snake oil.    cutting back the side electrode of any plug at different lengths does the same thing.  I always cut mine back so that it is halfway across the center electrode. David Vizard does this mod and even more  search him and much will come up.
Kokomo Kevin
Kokomo, Indiana
« Reply #6 on: June 30, 2018, 06:33:51 AM »
Copy will do, what do you think about iridium  plugs?
« Reply #7 on: June 30, 2018, 06:53:43 AM »
they work. IMO not worth the money compared to the champions and autolites that have reduced center electrodes also at a reduced cost, for the GL1500 engines.  Iridiums were originally designed for high compression, pressurized race engines which were blowing out the spark of normal plugs.  smaller center electrodes always help reduce the inherent mis-fires that always happen.  some info here based on Dr Jacobs book.  http://www.fierofocus.com/articles/Ray%20Paulk%20Article%20-%20Ignition%20Systems.htm
Kokomo Kevin
Kokomo, Indiana
« Reply #8 on: June 30, 2018, 07:38:28 AM »
Thanks, having read article and digested it, thinking about upgrading coils and plus. 20 year old bike runs well but thinking upgrade before a failure, Suggestions again on coils and plug combinations, thanks for input!
« Reply #9 on: June 30, 2018, 09:24:50 AM »
modern honda coils last a life time.
Funbaldguy
grand blanc Mi
« Reply #10 on: July 01, 2018, 02:36:40 PM »
ok those champion plugs you are using. Could you share the numbers? I just tried to look up by model and got no results. Please and thank you.
« Reply #11 on: July 01, 2018, 04:14:41 PM »
8812    some places sell them in a 8 pack for a reduced cost per plug.
https://www.sparkplugs.com/Motorcycle-SparkPlugsCom-c318.aspx
https://www.sparkplugs.com/product.aspx?zpid=26249
3W-lonerider
Shippensburg Pa
« Reply #12 on: July 01, 2018, 04:36:55 PM »
Been turning wrenches for 40 years now.
Champion plugs are only good for 1 thing. To get tailgaters off your ass the when 1 bounces off their hood.
« Reply #13 on: July 01, 2018, 05:06:31 PM »
2funny I've always felt the same. Jap bikes deserve Jap plugs. 2 strokes even more so.
« Reply #14 on: July 01, 2018, 05:49:05 PM »
so if u started in 1978, ('76-'77 on my own, few yrs before that with my dad) then u should know that champions were the plug for many in the 60s and 70s and were very good and in the late 70s early 80s they started to go down. about 10 yrs ago they became good again. I've been using these powersports for  12k miles at this time with great results.  originally started using them in lawn mowers, great results also.
MH please provide the test results, before/after dyno runs that back-up your statement. Because I've read the same anecdotal statements by mechanics on the websites for yrs.
3W-lonerider
Shippensburg Pa
« Reply #15 on: July 01, 2018, 06:07:13 PM »
The reason i say they never changed from being bad is this.
Every single time i get called out to a job site because of an engine that isn't running properly. I always find champion plugs in it. Install a good set of autolights.  Problem solved. Heres another one for you. Last year at a car show there was a guy there that had alot of different brands of plugs screwed into a sealed plexiglass box. He had all of them doing their job. Little by little he increased the pressure in the box the same as it would be in a cylinder. Champion plug was the first one to go out and not fire.
« Last Edit: July 01, 2018, 06:08:59 PM by 3W-lonerider » Logged
