February 14, 2026, 12:15:10 PM *
Author Topic: blinkers do not work  (Read 1042 times)
rocketray
« on: July 02, 2018, 07:52:31 AM »
at the Honda shop I had them put in a new blinker switch and they still  do not work--any idea's?
« Reply #1 on: July 02, 2018, 08:16:54 AM »
Flasher? Do All the bulbs work? Was the new switch installed correctly? Just cuz he a wrench at a dealer! RIDE SAFE.
« Reply #2 on: July 02, 2018, 09:39:42 AM »
who said it needed a new switch? I've had blinkers not work on a bike, but one side only, you knew the switch was at fault.
But if all your blinkers aren't working, and the switch seems to function properly (you can feel it), then I would suspect something else 1st. I would trace the wires down with a meter, and would suspect the flasher or plugs not connected.
« Reply #3 on: July 02, 2018, 06:52:47 PM »
Chances are the old switch had dried up OEM grease. A good cleaning and new grease probably would have fixed it. Your new issue should go back to the dealer.
Moonshot_1
« Reply #4 on: July 02, 2018, 07:01:26 PM »
Likely low on blinker fluid. (Damn it somebody had to say it.)
Actually we could use a little more background in the problem. How did you determine it was a switch problem? Was there any modifications done prior to this? When did they last work? What happened since?
A little more history on this would help.
Mike Luken
Cherokee, Ia.
Ramie
2001 I/S St. Michael MN
« Reply #5 on: July 03, 2018, 07:01:08 AM »
Good video on the turn signal switch.
https://www.youtube.com/watch?v=Ob4JWFQ6aTc
