February 14, 2026, 12:15:22 PM *
Author Topic: GREASE:: proper type, name brand for spline, pinon cup shaft re-assemble  (Read 1459 times)
VALARIE
« on: July 03, 2018, 07:02:10 PM »
Ok all, what type of lubrication, grease  type is best for this final drive  and pinion cup post-servicing,, does it need molly 60? is bel ray  assembly lube waterproof type ok?, does it have molly in it? what are you pros using... ,
« Reply #1 on: July 03, 2018, 07:06:35 PM »
I got a couple of tubes from my local honda dealer Free right when they changed the formula Honda was useing.......so I use that.....when that runs out I will be asking the same question....
George B
Marion Illinois
« Reply #2 on: July 03, 2018, 07:53:02 PM »
Splines on  the wheel hub get the moly 60. Sliding splines, like a drive shaft, I always use moly grease.
1997 1500CT with California Sidecar
Now a Roadsmith Trike conversion
Former rides:
1988 BMW R100GS
2007 Ural Patrol
15 HDs from 1937 to 1977
Ken aka Oil Burner
Mendon, MA
« Reply #3 on: July 03, 2018, 07:58:22 PM »
I just picked up some Locktite LB 8012 paste. It claims to be 65% moly (at least). Hopefully, it works well, since the Honda replacement for the discontinued moly 60 paste apparently isn't up to their own recommendations. Yes, I googled the heck out of the final drive spline situation, probably reading as much misinformation as I did good stuff.
https://www.henkel-adhesives.com/us/en/product/anti-seize-lubricants/loctite_lb_8012.html
The data sheet:  https://tdsna.henkel.com/NA/UT/HNAUTTDS.nsf/web/A1A6CD26FBD6F879882571870000DBB5/$File/LB%208012-EN.pdf
VALARIE
« Reply #4 on: July 03, 2018, 08:04:07 PM »
no kidding, im going in circles here, i think ill use belray assembly lube, good molly content, good for splines etc..
« Reply #5 on: July 03, 2018, 08:24:26 PM »
Many have used it with good effect. I still have some Honda 60 paste left. Probably go with the Locktite paste next. Honda switched to Moly77 paste. Do the proper tightening sequence.  cooldude
« Reply #6 on: July 04, 2018, 04:03:35 AM »
I have that assembly lube.  It looks great for our splines
  It's my experience that it dries out real bad if used alone.  I like it used in conjunction with Lucas heavy duty water resistant grease.
Dusty
Mill Bay B.C.
« Reply #7 on: July 04, 2018, 05:49:47 AM »
 I use this stuff. Extreme pressure and water resistant    cooldude cooldude
https://www.ebay.com/itm/1-NEW-CHEMSEARCH-MAXI-LUBE-RED-MULTI-PURPOSE-NLGI-2-ALUMINUM-COMPLEX-GREASE-NNB-/331965001138
Dusty
Ken aka Oil Burner
Mendon, MA
« Reply #8 on: July 04, 2018, 09:47:36 AM »
Interesting. So, how do you do the mix? Do you mix the two on something like cardboard, or do you brush on one and then put some of the other on after? I am no chemical engineer, so I don't know of any problems from combining the two. Do you think a moly-based grease would be the best plan? There are enough types of grease out there to make your head spin. Polyurea, calcium sulfonate, lithium, etc.
longrider
Vernon, B.C. Canada
« Reply #9 on: July 04, 2018, 03:59:55 PM »
I  use the moly mixed with grease as well.  Half and half.  Works well and doesn’t dry out
Daniel Meyer
The State of confusion.
« Reply #10 on: July 04, 2018, 04:00:47 PM »
Whatever grease will do ya...wheel drive splines are all about assembly. Do the 4 nuts thing and you'll never have an issue. I use regular water-proof wheel bearing grease. (quarter million miles so far). I also use it on the drive-shaft-to-ujoint and ujoint-to-engine splines.
Pinion cup now...a sticky one. Don't use the heavy paste...the manual calls for a VERY small amount of grease (not paste) as assembly lube. I just hit it with some rear drive oil, since that's how it's lubed anyway...but if you insist on grease, it's a light moly and just a dab.
CUAgain,
Daniel Meyer
