March 30, 2026, 07:55:44 PM *
Author Topic: lube belray  (Read 665 times)
VALARIE
« on: July 03, 2018, 08:08:04 PM »
97 valk, final drive,, ok to use belray assembly lube on spline, pin cup, drive shaft on re assemble??
« Reply #1 on: July 04, 2018, 03:54:00 AM »
I have used it.  It dries out really bad if used by itself.  It has good moly content so it's good but I'd ad some water resistant grease along with it.
« Reply #2 on: July 04, 2018, 06:16:20 AM »
I use the Belray Waterproof grease, Ive never had a problem But I used it on boat drives and couplers and it was the only grease that would stand up to the water and rpm and not be washed out. I use it now as my only grease on many applications also and never have a problem.
« Last Edit: July 04, 2018, 06:45:16 AM by Robert » Logged
« Reply #3 on: July 04, 2018, 06:31:38 AM »
Assembly lube and waterproof grease are not the same or interchangeable. Bel Ray Waterproof grease is the better product for wheel splines as it stays put. On the drive shaft I use Valvoline Durablend due it it having 3% a moly content.
indybobm
Franklin, Indiana VRCC # 5258
« Reply #4 on: July 04, 2018, 08:26:30 AM »
Same here. Works great.
So many roads, so little time
VRCC # 5258
« Reply #5 on: July 04, 2018, 11:17:16 AM »
I use the valvoline mixed with lucas waterproof grease. Has worked well for me.
