July 11, 2025, 09:25:57 AM *
Author Topic: Noise - I'm thinking it sounds like from the rear  (Read 1798 times)
Rowdy
Nerk, Ohio
« on: November 09, 2009, 10:58:21 AM »
 Sad Noise - a metalic sound - just sometimes - does not last long  ???
I orginally thought it might be some new stuff I put on the front, radiator cover & lower guard - seems to be coming from the rear, like something is rubing the fender occasionaly - I see nothing  Undecided
Could I have U-joint just starting to go bad ?
Could the rear wheel bearing starting to go bad ?
What are the signs  uglystupid2
Rowdy
99 Gr / Sv I/S
81 Bl CB900 Custom
73 Bl CL350 (sold)
06 Tit GL1800
77 GL1000 naked wing (Sold)
86 & 84 GL1200 wings (Sold)
Semper Fi "Leathernec
KY,Dave (AKA Misunderstood)
Specimen #30838 DS #0233
Williamsburg, KY
« Reply #1 on: November 09, 2009, 01:44:48 PM »
When I heard metal from behind it was the wheel bearing. It got progressivly worse til I knew for sure. Scarey sound.
« Reply #2 on: November 09, 2009, 01:51:24 PM »
When my last right rear wheel bearing started going bad the only sound it made was during stops...right at the end while braking there would be this short little grinding noise.  You can verify a bad wheel bearing by lifting the rear and with a strong grip try to make the wheel move laterally (side to side)  If the bearings are going you should detect a very very slight tic tic back and forth as you apply lateral pressure
« Last Edit: November 09, 2009, 01:53:45 PM by Chrisj CMA CR3M » Logged
F6MoRider
Lakeland, FL
« Reply #3 on: November 09, 2009, 02:03:41 PM »
My u-joint just failed.
Started as a quite whir, while driving two up at 80 - 85 mph but it only whirred immediately after backing off the throttle.  I could play with the throttle and recreate it, sounded like purring valves.  It was a very quite and cool evening and the wind was at my back.
Overnight, it immediately progressed to a clunking (metal to metal rub) on decel at about 2500 - 3500 rpm and sounded like it was coming from the timing belt area.  It didn't initially sound like it was originating from the back or the middle of the machine.
Within 20 miles, it was occurring almost immediately after starting forward movement but only when torque wasn't being applied.  Come to find out the torque was binding the arms together quieting the clunking, on decel they separated and clunked around. Smiley
This was my experience, your experience and results may vary ... but do let us know what you find and how your hunt goes.
VRCC #4086
2000 Valk Standard dressed with matching Interstate Bags and the Hondaline shield.
« Reply #4 on: November 09, 2009, 03:10:08 PM »
Could be your rear rotor. Mine did this rideing 2-up and turning left. Jack it up and spin it. I put a new to me rotor on but not sure if I did this right after or awhile. Either way the noice went away.
« Reply #5 on: November 09, 2009, 05:07:07 PM »
I think it's way too soon to worry about if you cannot pinpoint the source of the sound. The bike will not all the sudden stop from a mechanical kind of sound and if it is a problem it will eventually reveal the problem.
Just keep alert and sometimes it'd good to mark on the calendar to keep track of happenings.
Gore
Denver CO
« Reply #6 on: November 12, 2009, 08:33:46 AM »
Does it go away when you pull in the clutch?
Check if your drive splines are lubed.
There's a page on VRCC that talks about common Valk problems.
This happened to me.
We gonna ride or we gonna dick around all day?    Okay good, let me just finish my coffee, find my key, grab gloves, call the woman, top-off, check my . . . . . . .
