November 14, 2025, 04:22:15 PM
Shift rod seal
Topic: Shift rod seal (Read 994 times)
CleoBen
2000 Interstate
Lewisburg. Ohio
Shift rod seal
July 08, 2018, 06:59:19 AM »
I have the pipes off and the desmog kit installed. I've replaced most of the fuel and vacuum tubing while I'm in this far. I found a very small oil leak starting from the shift rod at the tranny case that I'd like to fix while the pipes are off.
Can the used seal be removed and replaced with a new one without opening the tranny? Any suggestions or tips?
CB
2000 I/S, 60K miles, unknown maintenance history
Re: Shift rod seal
July 08, 2018, 07:01:18 AM »
yes very easy I used a hook ice pic others have screwed a screw into the seal to pull on....tap the old one in more to reseal it until the new one arrives
CleoBen
2000 Interstate
Lewisburg. Ohio
Re: Shift rod seal
July 08, 2018, 07:15:54 AM »
Quote from: Chrisj CMA on July 08, 2018, 07:01:18 AM
Thanks Chrisj. I have the new one in hand, so I'm good to go.
CB
Re: Shift rod seal
July 08, 2018, 08:22:38 AM »
Put a dab of grease on the inside of that seal Before you install it. Also clean the opening Before install of new seal. Onlyiest time She EVER leaked oil on mine were from that shifter seal. RIDE SAFE.
Paladin528
Re: Shift rod seal
July 12, 2018, 09:23:50 AM »
I did mine without even removing the exhaust. piece of cake
Daniel Meyer
The State of confusion.
Re: Shift rod seal
July 12, 2018, 11:45:49 AM »
http://lifeisaroad.com/valkshiftseal.html
CUAgain,
Daniel Meyer
Forge
San Antonio, TX
Re: Shift rod seal
Reply #6 on:
July 12, 2018, 01:56:58 PM »
I just did mine a few days ago. Piece of cake. I was changing exhaust gaskets and my oil anyway. I drilled a tiny hole in the seal and screwed a drywall screw into it just enough to grip and was able to pull it out by hand. I greased up the new seal and pressed it most of the way in by hand and used the round end of a box end wrench to finish pushing it in. Done.
=> InZane XXV
