Tfrank59
'98 Tourer
Western Washington
« on: July 08, 2018, 07:54:00 AM » |
So my rear tire leaks down like 2-3 psi in 2-3 days. I have the permanent metal valve stems, and I've not replaced the valve core since new--3 tires ago. Can I just remove and replace the valve core, if I'm careful not to break the bead? I know it's not tire or rim damage
-Tom
Keep the rubber side down. USMC '78-'84 '98 Valkyrie, ‘02 VTX 1800, '96 Royal Star, '06 Drifter, '09 Bonneville, '10 KTM 530, '04 XR 650, '76 Bultaco, '81 CR 450, '78 GS 750...
« Reply #1 on: July 08, 2018, 07:57:50 AM » |
You almost certainly won't break the bead by taking the core out. Make sure the bike doesn't fall on you though, it might stand up enough on the kick-stand to do it.
Tfrank59
'98 Tourer
Western Washington
« Reply #2 on: July 08, 2018, 08:16:42 AM » |
thanks. I was thinking of having it on the lift
-Tom
« Reply #3 on: July 08, 2018, 08:18:56 AM » |
Did that metal valve stem tighten from the inside or the outside? Either way put soap water on the stem itself where it meets the wheel. If it were me and I wuz gonna R & R the valve core I'd have my Phatt Ghurl on the lift Just in case!. Course I'm runnin a dark side rear anywho. Cain't remember the brand but the metal valve stems I use tighten from the outside. And-B T W-valve cores are relatively inexpensive. RIDE SAFE.
« Reply #4 on: July 08, 2018, 08:21:26 AM » |
With the cap off, are you getting soapy bubbles from the valve stem? This can be tested with more air pressure than normal.
It's not impossible to have a rim leak (even without rim damage).
Not that changing out the shrader valve anyway isn't a good idea.
Tfrank59
'98 Tourer
Western Washington
« Reply #5 on: July 08, 2018, 08:25:13 AM » |
my valves tighten from the outside (can't remember the brand, but it's the one recommended on this forum). I'll get her up on the lift and try the soapy water thing around the valve, even before attempting to replace the core. Thanks!
-Tom
« Reply #6 on: July 08, 2018, 08:28:29 AM » |
It’s entirely possible that it’s the schrader valve. I’d but the odds are better that it’s a dirty bead seat. It’s amazing how much rubber and gunk get stuck on there.
« Reply #7 on: July 08, 2018, 08:32:27 AM » |
That's the WHY of a Good tire tech and a good stiff brush checking for and eliminating the gunchy crud-tech term-that accumulates in the rim bead.  RIDE SAFE.
Toledo Mark
Formerly Zeus661
Rossford, Ohio
« Reply #8 on: July 08, 2018, 10:57:09 AM » |
Do you have balancing beads in The Tire?
 ************************************************************** Dropbox is a neat app I found that I use to store files and pictures of my Valk. **
Tfrank59
'98 Tourer
Western Washington
« Reply #9 on: July 08, 2018, 11:06:51 AM » |
No sir, no beads inside
« Last Edit: July 08, 2018, 11:16:48 AM by Tfrank59 »
-Tom
Ramie
« Reply #10 on: July 09, 2018, 06:55:12 AM » |
I had to replace my rear tire last year. I was loosing a small amount of pressure each week. Thought it might be a bad valve but when I pulled the rear wheel and set up a tank in a re-enforced cardboard box lined with plastic. I discovered the tire (an Avon cobra) had small pinhole leaks in the tread.
“I am not a courageous person by nature. I have simply discovered that, at certain key moments in this life, you must find courage in yourself, in order to move forward and live. It is like a muscle and it must be exercised, first a little, and then more and more. A deep breath and a leap.”
« Reply #11 on: July 09, 2018, 07:24:23 AM » |
That sounds like a lot of work to find a leak. A spray bottle with soapy water (dish soap) is far easier; spray an area, looking for growing bubbles, then roll the bike forward and spray the next section, repeating until you've done the whole tire and found the leak(s).
« Reply #12 on: July 09, 2018, 07:25:11 AM » |
Remember....replacing the valve CORE is merely a case of removing the insides of the stem, often with the valve cap itself. It doesn't involve breaking the bead because you're not doing anything to the stem or tire. If you're replacing the valve STEM, then yes....you have to break the bead because it involves being able to get at the stem from the inside. Check for leaks with soapy water as suggested, or just do as I do....spit on it and if leaking you still get bubbles. No need to hock a big lugy, just a dab of saliva is sufficient.
« Reply #13 on: July 09, 2018, 07:39:32 AM » |
That sounds like a lot of work to find a leak. A spray bottle with soapy water (dish soap) is far easier; spray an area, looking for growing bubbles, then roll the bike forward and spray the next section, repeating until you've done the whole tire and found the leak(s). I spent a long time (numerous tedious revolutions) finding one AVON pinhole leak using a spray bottle of soapy water once. I had just installed the tire and didn't relish the thought of pulling it off. When I found the leak and saw that it was in the tread, that's when I finally decided to try Ride On for the first time. The Ride-On people don't really mean for you to put Ride-On in after you get a leak, but I figured it couldn't hurt to try it on this pinhole leak. I wore that tire out with no further leakage. -Mike
Tfrank59
'98 Tourer
Western Washington
« Reply #14 on: July 09, 2018, 08:08:43 AM » |
Well I got down there and noticed that the nut that holds the valve was barely snug so I got a 15 millimeter wrench and snugged it up, also the front tire valve stem, so I'll keep you posted, but I think that fixed the problem. I'm sure those can be over tightened and start leaking from that but like I said this was just like hand tight and after about 2 or 3 years it needed to be re snugged
-Tom
« Reply #15 on: July 09, 2018, 08:40:18 AM » |
That sounds like a lot of work to find a leak. A spray bottle with soapy water (dish soap) is far easier; spray an area, looking for growing bubbles, then roll the bike forward and spray the next section, repeating until you've done the whole tire and found the leak(s). I spent a long time (numerous tedious revolutions) finding one AVON pinhole leak using a spray bottle of soapy water once. I had just installed the tire and didn't relish the thought of pulling it off. When I found the leak and saw that it was in the tread, that's when I finally decided to try Ride On for the first time. The Ride-On people don't really mean for you to put Ride-On in after you get a leak, but I figured it couldn't hurt to try it on this pinhole leak. I wore that tire out with no further leakage. -Mike Okay, I should have added that when looking for bubbles, use reading glasses.
Ramie
« Reply #16 on: July 10, 2018, 07:16:15 AM » |
Remember....replacing the valve CORE is merely a case of removing the insides of the stem, often with the valve cap itself. It doesn't involve breaking the bead because you're not doing anything to the stem or tire. If you're replacing the valve STEM, then yes....you have to break the bead because it involves being able to get at the stem from the inside. Check for leaks with soapy water as suggested, or just do as I do....spit on it and if leaking you still get bubbles. No need to hock a big lugy, just a dab of saliva is sufficient.  It was a lot of extra work but I tried a number of times to check the valve stem and found no leak, so I pulled the rear wheel. Wanted to check rear end anyway.
