March 30, 2026, 05:57:10 PM *
Author Topic: cleaning chrome pipes?  (Read 933 times)
Spurs
Summerfield, FL
« on: July 08, 2018, 01:01:14 PM »
got some melted fiber cleaning cloth on my chrome pipes-how to remove?
1997 Valk Std
2014 Indian Vintage
2016 Polaris Slingshot
Politicians and diapers need to be changed often and for the same reason. Mark Twain
« Reply #1 on: July 08, 2018, 01:07:17 PM »
Try some crumpled up aluminum foil, chrome polish and finish with glass cleaner.
If I remember correctly DDT told me about that.....  Wink
Edited: The crumpled up aluminum foil method requires a light touch!
As with any abrasive material, the more aggressive you get, the greater the danger of going too far exists.
« Last Edit: July 15, 2018, 05:10:58 AM by Rams » Logged
« Reply #2 on: July 08, 2018, 01:41:40 PM »
While it can burn your hands (so protect them), some stuff comes off easier when heated up.
Patience, the chrome will get rubbed (if you rub too hard).
Oven cleaner is said to work.  (some works hot, some works cold)
« Reply #3 on: July 08, 2018, 02:23:33 PM »
Get some quality metal polish and it does take some elbow grease but will come off and leave no scratches.
bludragon
Montreal, Quebec, Canada
« Reply #4 on: July 14, 2018, 01:48:17 AM »
I just purchased some oven cleaner and instructions mention not to use it on chtome.  Any comments from someone who has used it would be appreciated
Thank You
Dusty
Mill Bay B.C.
« Reply #5 on: July 14, 2018, 06:38:54 AM »
I used easy off oven cleaner on the chrome to get boot marks off. I wouldn't leave it on for a week like I did with the chrome oven racks that I forgot to hose off (it discolored the chrome ).
I tried the aluminum foil trick and scratched the pipes so I won't be trying that anymore.
Dusty
« Reply #6 on: July 14, 2018, 06:53:51 AM »
Dusty
My guess is, you we’re too aggressive but , I wasn’t there.  Has worked for me on several chrome items
_Sheffjs_
Jerry & Sherry Sheffer
Sarasota FL
« Reply #7 on: July 14, 2018, 09:50:45 AM »
Sherry had her boots resting on the pipes and melted a nice black spot on them and while super hot after we pulled into the garage I took a piece of soft pine wood used for a wedge or shim and it worked amazing.  Came right off
97BLKVALK
VRCC#26021
Detroit Lakes, MN
« Reply #8 on: July 14, 2018, 01:31:48 PM »
Steel Wool of the quadruple  ought fineness.
Michael
1997 GL1500C - Black
1997 GL1500C - Purple
1997 GL1500C - Bumble Bee
1998 GL1500C - Blue and Cream
« Reply #9 on: July 14, 2018, 01:59:26 PM »
Michael
 cooldude    with chrome polish/cleaner
Dusty
Mill Bay B.C.
« Reply #10 on: July 14, 2018, 08:06:03 PM »
Dusty
I should of practiced on an old crash bar . It's scratched now and a new  muffler cover is the only solution so live and learn
Dusty
« Reply #11 on: July 15, 2018, 05:13:27 AM »
Michael
Yep,  0000 steel wool rubbed lightly with some cheap turtle wax branded chrome polish you get in a green bottle at walmart for a few bucks works wonders.  It also removes most small rust spots on chrome as well with a cloth rag I try first before using 0000 steel wool.
« Reply #12 on: July 15, 2018, 07:57:42 AM »
I use 0000 steel wool wetted with WD40 which is a great chrome cleaner. I buy the WD40 by the gallon to wet the SS well. Don't scrub with it, just use the SS as a carrier to hold the WD40.  Not saying it will clean everything - but most everything.
Thunderbolt
Worthington Springs FL.
« Reply #13 on: July 15, 2018, 09:14:54 AM »
Pick up some cleaning pads at Dollar Tree or Big Lots for a dollar a box that have soap inside.  They work great for taking off surface rust on pipes and probably will do what you want.  Be sure to rewax everything you clean.
